    Accessing primitive object geometry [SOLVED]
    12 Posts 0 Posters 1.1k Views
      On 12/05/2015 at 01:47, xxxxxxxx wrote:
      It is simply not possible.
      The only way to do that, is to make it editable.
      What you could do, is make an object-generator plugin and add the methods yourself (GetPolygonR()), but I don't know if that's what you want.
      If you have more questions, just ask.
      Greetings,
      Casimir Smets
        On 12/05/2015 at 02:00, xxxxxxxx wrote:
        Thanks for your reply Casimir,
        I am not completely sure it is impossible, if you take a look at the X-particles plugin, you can make an emitter that collides with a primitive cube with a collider tag on it, and the cube is not even editable. The only way to simulate this correctly is having access to the object geometry inside X-particles... somehow X-particles is doing it.
        cheers.
          On 12/05/2015 at 02:14, xxxxxxxx wrote:
          I do this inside my plugin and it works fine.  Although my plugin is an ObjectData plugin with the OBJECT_MODIFIER flag..
          What i do is just cast the object as a polygonal object and go from there..
          So you can use:
          ToPoly(op)->GetPolygonR();
          or:
          static_cast<PolygonObject*>(op)->GetPolygonR();
          Something like that..
            On 12/05/2015 at 02:17, xxxxxxxx wrote:
            Hi Enrique,
            You can get the geometry information for a primitive object with BaseObject::GetCache().
            Check the type of the returned object and cast it to the appropriate type i.e. PolygonObject in most cases.
              On 12/05/2015 at 02:30, xxxxxxxx wrote:
              Well, I guess I was wrong, sorry for my bad information!
              I didn't think of casting it 😛
              Greetings,
              Casimir Smets
                On 12/05/2015 at 02:41, xxxxxxxx wrote:
                Hi Casimir,
                Casting the primitive object, does not work. Casting the cache object returned by GetCache() does work.
                  Hi Casimir,
                  Am i missing something?  As i said in my post above it works fine for me without using the Cache at all..  But again, that is with an ObjectData OBJECT_MODIFIER plugin..
                    On 12/05/2015 at 03:14, xxxxxxxx wrote:
                    Is it an FFD deformer object? You can cast any object to a PointObject if it has a Tpoint Tag on it. Same goes for a PolygonObject if it has a Tpolygon tag on it (and a Tpoint tag).
                      Hi Enrique,
                      Thank you very much Yannick, you are absolutely right. It works!
                      However, now that we talk about deformers, if I have the very same cube deformed, the geometry I get with those methods is the original geometry, not the deformed one. do you know how to get the modified one?
                        On 12/05/2015 at 04:42, xxxxxxxx wrote:
                        From GetCache(), scroll down just a little bit and you will find it 😉
                          Thanks Niklas, I forgot to mention that I was already using that 🙂. I don't know what the problem was at first that it didn't work, but now it is working.
                          Everything is correctly imported now 🙂
