    Gradient evaluation outside of render
    10 Posts 0 Posters 780 Views
      On 08/05/2015 at 11:31, xxxxxxxx wrote:
      Cinema 4D Version:   15
      Platform:   Windows  ; Mac  ;
      It seems the gradient calculate function requires InitRender to be called first.
      Is there a way to evaluate CalcGradientPixel without a render structure or is there a way to initialize the render structure without volume data?
      Ama
        On 08/05/2015 at 11:43, xxxxxxxx wrote:
        Here is what I tried:
        colorGradient = (Gradient* )data->GetCustomDataType( GRADIENTID, CUSTOMDATATYPE_GRADIENT );
        InitRenderStruct renderStruct;
        renderStruct.Init( bn->GetDocument() );
        VolumeData *volumeData = VolumeData::Alloc();
        renderStruct.vd = volumeData;
        colorGradient->InitRender( renderStruct );
        I am confused why this not working.
        then try to calculate.
        Ama
          On 09/05/2015 at 02:53, xxxxxxxx wrote:
          You don't need no VolumeData for the GradientData. Maybe that is the problem, it works for me with an
          empty InitRenderStruct.
            On 09/05/2015 at 04:22, xxxxxxxx wrote:
            thanks,
            are you initializing that render struct?
            Ama
              On 09/05/2015 at 05:52, xxxxxxxx wrote:
              Nope. Here's how it works in Python:
                  gradient = op[c4d.ID_USERDATA,1]
                  irs = c4d.modules.render.InitRenderStruct()
                  res = gradient.InitRender(irs)
                  if res != c4d.INITRENDERRESULT_OK:
                      print "InitRender() failed"
                  try:
                      for i in xrange(10) :
                          x = i / 9.0
                          print gradient.CalcGradientPixel(x)
                  finally:
                      gradient.FreeRender()
              And I remember successfully doing it in C++ without calling InitRenderStruct::Init().
                On 10/05/2015 at 07:25, xxxxxxxx wrote:
                I am trying to get this working within an xpresso node.  If I access the gradient directly from the res file it all works fine.  If I access it through a port, it initializes, has the correct render knot count, but crashes on Calc or FreeRender.
                Ama
                  On 11/05/2015 at 10:05, xxxxxxxx wrote:
                  can you tell us what exactly you mean with "working within an xpresso node"? Are you creating your own GvOperatorData plugin?
                    On 11/05/2015 at 10:27, xxxxxxxx wrote:
                    I have created a GvOperatorData plugin.  The problem is that I can not use a port for the gradient successfully.  If I use the res static gradient is all fine.  If I use the port gradient, it will init but crashes when calc or free is called.
                    Ama
                      On 12/05/2015 at 10:00, xxxxxxxx wrote:
                      in an Xpresso node, you don't handle parameters but ports. These ports must be handled in special ways:
                      static Int32 input_ids[] = { GV_TEST_A, GV_TEST_B, 0 };
                      GvValuesInfo ports; // data structure for all ports
                      // init the input ports
                      virtual Bool InitCalculation(GvNode *bn, GvCalc *calc, GvRun *run)
                        return GvBuildValuesTable(bn, ports, calc, run, input_ids);;
                      virtual Bool Calculate(GvNode *bn, GvPort *port, GvRun *r, GvCalc *calc)
                        // calculate all ports
                        if (!GvCalculateInValuesTable(bn, r, calc, ports)) return false;
                        // get the "Gradient" port
                        GvPort* portGradient = ports.in_values[0]->GetPort();
                        // get the "Gradient" data
                        Gradient* gradient = nullptr;
                        portGradient->GetDataInstance((const void*&)gradient, CUSTOMDATATYPE_GRADIENT, r);
                        // sample the gradient
                        if(gradient != nullptr)
                            InitRenderStruct irs(bn->GetDocument());
                            gradient->InitRender(irs);
                            for(Int32 i = 0; i < 10; i++)
                                Vector color = gradient->CalcGradientPixel(Float(i) / 10.0);
                                GePrint(String::VectorToString(color));
                            gradient->FreeRender();
                        return true;
                      // free data
                      virtual void FreeCalculation(GvNode *bn, GvCalc *calc)
                        GvFreeValuesTable(bn, ports);
                        On 22/05/2015 at 08:55, xxxxxxxx wrote:
                        Hello Ama,
                        was your question answered?
