    add shader in user data [SOLVED]
    5 Posts 0 Posters 486 Views
      On 29/04/2015 at 16:00, xxxxxxxx wrote:
      hi
      i try to add a new gradient shader to a shader field in my user data
      insertShader don`t work with the user data field
      shader = c4d.BaseList2D(c4d.Xgradient)
                          	gradient = shader[c4d.SLA_GRADIENT_GRADIENT]
                          	gradient.InsertKnot(Value,1,0)
                          	shader[c4d.SLA_GRADIENT_GRADIENT] = gradient
                          	node[id].InsertShader(shader)
      i
        On 30/04/2015 at 07:37, xxxxxxxx wrote:
        InsertShader() does not assign a shader to a specific parameter. This function is used to add a shader to a host object so it can be part of the document. So you have to assign the created shader to your userdata parameter in addition to using InsertShader(). You find an example on how to do this in the  documentation of the function.
          On 30/04/2015 at 12:51, xxxxxxxx wrote:
          this don`t work
          it clear the actually Shader from the user data but don`t add the new one
                              	node[id] = shader
            node[id] = shader
            node.InsertShader(shader)
              On 30/04/2015 at 14:07, xxxxxxxx wrote:
              thanks Niklas
