    InsertMaterial in ObjectData plugin [SOLVED]
    27 Posts 0 Posters 17.2k Views
      On 30/04/2015 at 02:49, xxxxxxxx wrote:
      in order to use materials they need to be inserted into the scene. You can't do that from inside GVO.
      Instead you can do this inside Message() function. MSG_MENUPREPARE is the one you'll want to use. This message is send, when your plugin is called from the menu, so basically at the moment your object gets created. The corresponding data is the current BaseDocument.
        On 30/04/2015 at 03:19, xxxxxxxx wrote:
        Hi Andreas,
        I was allready testing inside MSG_MENUPREPARE.
        My problem is, when I start my plugin, I get a bugreport.
        Here is the code I use:
        Bool MyPluginData::Message(GeListNode* node, Int32 type, void* data)
          if (type == MSG_MENUPREPARE)
              BaseDocument* doc = node->GetDocument();
              BaseMaterial* myMaterial = BaseMaterial::Alloc(Mbase);
              doc->InsertMaterial(myMaterial);
          return true;
        Does anybody see the problem here?
        Greetings,
        Casimir Smets
          On 30/04/2015 at 03:38, xxxxxxxx wrote:
          Hi Casimir,
          did you try to use the document provided by the message? The corresponding data is the current BaseDocument.
            On 30/04/2015 at 05:52, xxxxxxxx wrote:
            Hi Andreas,
            If I put BaseDocument* doc inside my parameters of Message, I get no error when using my plugin, but the material doesn't show either in the material manager.
            Could this be because of some missing elements, or probably something else?
            Greetings,
            Casimir Smets
              On 30/04/2015 at 05:59, xxxxxxxx wrote:
              Hi Casimir,
              what do you mean by putting "BaseDocument* doc inside my parameters of Message"?
              Do you mean, you are changing the prototype of Message? That cannot work.
              Instead cast the data parameter (void* type) into a BaseDocument pointer. Like so:
              BaseDocument* doc = static_cast<BaseDocument*>data;
              Of course only in the case of MSG_MENUPREPARE.
                On 30/04/2015 at 06:28, xxxxxxxx wrote:
                Hi Andreas,
                Yes, I was wrong, I changed the prototype of Message, which I shouldn't do.
                However, if I do it your way, with the static cast, I have the same result: no errors but nothing happens in the material editor...
                Greetings,
                Casimir Smets
                  On 30/04/2015 at 06:30, xxxxxxxx wrote:
                  Also, as soon as I add: myMaterial->SetName("myMaterial"); the program crashes.
                  Greetings,
                  Casimir Smets
                    On 30/04/2015 at 06:44, xxxxxxxx wrote:
                    Well, after some testing with GePrint I found out that
                    does nothing.
                    Does somebody know how this could come?
                    Greetings,
                    Casimir Smets
                      On 30/04/2015 at 06:50, xxxxxxxx wrote:
                      I guess I've found the problem and I think that it is a bug:
                      If I replace:
                      with:
                      BaseMaterial* myMaterial = BaseMaterial::Alloc(Mmaterial);
                      everything works fine.
                      Greetings,
                      Casimir Smets
                        On 30/04/2015 at 08:35, xxxxxxxx wrote:
                        glad you got it working.
                        As explained in this thread Possible bug with Mbase (material) this is no bug.
                          On 30/04/2015 at 11:08, xxxxxxxx wrote:
                          Ok, that makes sense.
                          But why is Mbase listed in Material Types?
                          I think that's what confused me.
                          Also, this thread my be marked as solved.
                          Greetings,
                          Casimir Smets
                            On 04/05/2015 at 05:11, xxxxxxxx wrote:
                            Yet another question, related to this context.
                            I've got my material working inside my plugin. My next problem is, how do I change the material's color if the user changes the color slider? I've tried inside MSG_CHANGE, but that doesn't work.
                            Does somebody have any ideas on how to do this?
                            Greetings,
                            Casimir Smets
                              On 04/05/2015 at 19:40, xxxxxxxx wrote:
                              Assuming that you mean the basic color of the material, you need to get the Color channel and set its value where r, g, b are float values between 0.0 and 1.0:
                              BaseChannel* bchan = mat->GetChannel(CHANNEL_COLOR);
                              if (bchan)
                              	mat->SetParameter(DescID(MATERIAL_COLOR_COLOR), GeData(Vector(r, g, b)), DESCFLAGS_SET_DONTCHECKMINMAX);
                              This is probably a bit long in the tooth (from an older plugin) so be aware that constant ids may be different.
                                On 05/05/2015 at 02:39, xxxxxxxx wrote:
                                Thanks for your answer, but I allready found that out.
                                My question is, inside which method should I do this?
                                I probably wasn't clear enough in my previous post.
                                I've tried allready inside a few messages, with no results, mostly c4d crashing.
                                Does anybody know where to do it?
                                Thanks for your help and time!
                                Greetings,
                                Casimir Smets
                                  On 05/05/2015 at 12:55, xxxxxxxx wrote:
                                  if you want to react to the (manual) change of a parameter you could listen to the MSG_DESCRIPTION_POSTSETPARAMETER message in your object.
                                  For questions no longer related to this thread's original topic please open a new thread. Thanks
                                    On 06/05/2015 at 03:38, xxxxxxxx wrote:
                                    Hi Sebastian!
                                    I've allready tried it inside MSG_DESCRIPTION_POSTSETPARAMETER, but then c4d crashes...
                                    I guess it should be possible.. somewhere.
                                    Does anybody know where to do this?
                                    Greetings,
                                    Casimir Smets
                                      On 07/05/2015 at 10:05, xxxxxxxx wrote:
                                      Hi Casimir,
                                      can you give us an example of the code you used in MSG_DESCRIPTION_POSTSETPARAMETER?
                                        On 08/05/2015 at 01:18, xxxxxxxx wrote:
                                        Hi Andreas,
                                        I've used this code:
                                        BaseMaterial* myMaterial = doc->SearchMaterial("My_Material");
                                        if (!myMaterial)
                                          return nullptr;
                                        BaseContainer* myMaterialData = myMaterial->GetDataInstance();
                                        if (!myMaterialData)
                                          return nullptr;
                                        myMaterialData->SetParameter(MATERIAL_COLOR_COLOR, bc->GetData(MYMATERIAL_DIFFUSE_COLOR));
                                        myMaterial->Update(true, true);
                                        I also recently found out that I do not need to do this inside Message. I can simply use this in GetVirtualObjects and everything works fine.
                                        Still thanks for your help and time! 🙂
                                        Greetings,
                                        Casimir Smets
                                          On 08/05/2015 at 01:22, xxxxxxxx wrote:
                                          1. Make sure this does not result in recursion (due to the SetParameter call)
                                          2. You shouldn't change the active scene from within GetVirtualObjects. See threading information in the docs.
                                            On 08/05/2015 at 02:40, xxxxxxxx wrote:
                                            Hi Katachi,
                                            What do you mean by recursion? I've translated it and I know it means repetition, but what repetition?
                                            And secondly, I know I shouldn't change materials in a threaded-function, but because it didn't work in ANY message, I had to do it somewhere else. Besides, it seems to have no problem with it..   although it could give a bigger problem that I do not know about.
                                            If you would know another way how I could do this, I would greatly appreciate it!
                                            Greetings,
                                            Casimir Smets
