    GUI Step not working [SOLVED]
    2 Posts 0 Posters 224 Views
      On 21/04/2015 at 12:05, xxxxxxxx wrote:
      Cinema 4D Version:   R16
      Platform:      Mac OSX  ;
      I'm working on an object-generator plugin, which has some GUI sliders.
      As soon as I add the step inside my .res file, I can't use the up-arrow inside Cinema 4D and the step doesn't work. If I delete the step, all works fine.
      This is my line of code:
      REAL LENGTH { UNIT METER; MIN 5.0; STEP 0.5; }
      Did anybody have the same problem?
      And how can this be fixed?
      Thanks for your help and time!
      Greetings,
      Casimir Smets
        On 22/04/2015 at 01:48, xxxxxxxx wrote:
        Turns out my question was stupid. Inside my Init method I set my sliders.
        Previously I did it with data->SetInt32() which I have now replaced with data->SetFloat().
        Because an integer doesn't have decimals, my steps can't work. Logic.
        You can mark this post as solved!
        Greetings,
        Casimir Smets
