    Communicating data between two plugins
    8 Posts 0 Posters 713 Views
      On 13/04/2015 at 07:57, xxxxxxxx wrote:
      I have two plugins that live in different Python Plugin files. I know that we can use the Message system
      to pass Python objects around Python Plugins, but this only works with NodeData Plugins like Objects,
      Tags, etc.
      Plugin B provides a GUI that Plugin A needs data from. As it only implements a GUI, there is only a
      CommandData in Plugin B. How can I allow Plugin A to communicate with Plugin B and exchange
      Pythonic data?
        On 13/04/2015 at 15:07, xxxxxxxx wrote:
        Is it too simple/obvious or blundering to use maybe just a global basecontainer, populate that from the gui, and read from it with the nodedata plugin..
          On 14/04/2015 at 00:20, xxxxxxxx wrote:
          Hi Eclektrik,
          I can not just put any Python object in a BaseContainer, and I would have to place the container
          somewhere Plugin A can find it, eg. in the World or Plugin Data Container. I would prefer to exchange
          any Python objects between the Plugins.
          However, I just got the idea that I could just make an Object or Tag
          plugin, add methods it that should function as the API, and it does
          not need to be inserted in the document.
          def get_api() :
              return c4d.BaseTag(ID_MY_API_PLUGIN).GetNodeData()
          Niklas
            On 14/04/2015 at 08:11, xxxxxxxx wrote:
            Hi Niklas,
            How would yo use your function get_api()?
              On 14/04/2015 at 08:55, xxxxxxxx wrote:
              Hi Yannick,
              my_plugin.pyp
              class MyAPI(c4d.plugins.TagData) :
                  PLUGIN_ID = 124242  # just a random ID, not registered
                  def get_welcome_message(self) :
                      return "Hello from my_plugin.pyp!"
                  # register MyAPI as a TagPlugin ...
                  pass
              Script Manager
              def get_my_api() :
                  return c4d.BaseTag(124242).GetNodeData()
              api = get_my_api()
              print api.get_welcome_message()
              I'll write a blog post in a few days and will link it here.
              Niklas
                On 14/04/2015 at 10:32, xxxxxxxx wrote:
                I wonder how
                can return a valid BaseTag there if the TagData is not registered?
                  On 14/04/2015 at 10:40, xxxxxxxx wrote:
                  I wanted to keep the snippet short so I only added a comment that MyAPI needs to be registered. Reread the snippet 🙂
                    On 14/04/2015 at 10:51, xxxxxxxx wrote:
                    Ah ok 🙂. The comment for PLUGIN_ID confused me:
