    Wrap helix around spline
    12 Posts 0 Posters 1.2k Views
      On 09/04/2015 at 08:04, xxxxxxxx wrote:
      Yes, I use the splinehelp class frequently.
      But sometimes i wonder about the difference between the splinehelp and the normal spline.
      -Pim
        On 09/09/2015 at 17:12, xxxxxxxx wrote:
        I'm also trying to find a solution to wrapping a helix around a spline, but am not getting the results I was expecting multiplying the normal or tangent to my point.  Here is my code:
        #sh = c4d.utils.SplineHelp()
        #spLen = sh.GetSplineLength()
        def Helix(myLine, sh, spLen, stitchAmount) :
            v = c4d.Vector
            offSet = 0
            ptIncrement = 0
            a = 0
            direction = [v(0, 1, 0), v(0, 0, 1), v(0, -1, 0), v(0, 0, -1)]
            myHelix = c4d.SplineObject(64*stitchAmount,c4d.SPLINETYPE_BEZIER)
            seg = (spLen/stitchAmount)/64
            xx = 0
            for i in range(64*stitchAmount) :
                n = sh.GetNormal(offSet)
                pos = sh.GetPosition(offSet)
                myHelix.SetPoint( xx, v(pos.x + 40*n.x*direction[a].x, pos.y + 40*n.y*direction[a].y, pos.z + 40*n.z*direction[a].z))
                offSet = offSet + seg/spLen
                xx += 1
                a += 1
                if a == 4:
                    a = 0
            myHelix[c4d.SPLINEOBJECT_TYPE] = 1
            myHelix[c4d.SPLINEOBJECT_INTERPOLATION] = 2
            myHelix[c4d.SPLINEOBJECT_SUB] = 4
            myHelix.Message(c4d.MSG_UPDATE)
        Did you find a solution Pim?
          On 10/09/2015 at 01:38, xxxxxxxx wrote:
          I just want to add that there may be some problems with the SplineHelp class, see "c4d.utils.splinehelp".
            On 10/09/2015 at 14:16, xxxxxxxx wrote:
            Thanks for the tip Sebastian.  I haven't come up with a working solution yet even after trying the cross normal and other combinations, but when I do, I'll post my results.
              On 11/09/2015 at 00:08, xxxxxxxx wrote:
              Hi visualride,
              No, I did not find a solution yet.
              If you find one, I would be very interested.
              -Pim
                On 11/09/2015 at 09:11, xxxxxxxx wrote:
                It's good to hear that I'm not the only one not figuring this out Pim.  You know when you have looked for something for hours and then start to look even in the most un-logical locations, such as for a missing sock in the refrigerator?  That's where I'm at with combinations of changing point directions combined with normal/tangent/crossnormal, and recently, trying various up vector directions in the SplineHelp.InitSpline.  I get close results with the helix spiraling around my winding spline great in some directions, but then flattening out on some axis in others.  Seems to be a problem getting the correct normals off the spline that I'm using.  I'll try to sneak in another hour of trial and error Python programming from my usual day of C4D work.  Programming is never appreciated as billable work by my employers probably because it can't be billed on a current job.  Hence the constant "sneaking" in of time to program. But it's fun!
                  On 11/09/2015 at 16:55, xxxxxxxx wrote:
                  Ok, I've finally got it.  It may not be beautiful, and of course the real programmers may wince at some of my inefficiencies, but it works.  Here it is:
                  def Helix(myLine, stitchAmount) :
                      v = c4d.Vector
                      sh.InitSpline(myLine,c4d.Vector( 0, 0, 0 ),None,True,True,True,False)
                      offSet = 0
                      a = 0
                          t = sh.GetTangent(offSet)
                          if a == 0:
                              myHelix.SetPoint( i, v(pos.x + 40*n.z, pos.y, pos.z + 40*n.x*-1)) # Inward spline
                          if a == 1:
                              myHelix.SetPoint( i, v(pos.x, pos.y + 40*t.y, pos.z)) # Lower spline
                          if a == 2:
                              myHelix.SetPoint( i, v(pos.x + 40*n.z*-1, pos.y, pos.z + 40*n.x)) # Outward spline
                          if a == 3:
                              myHelix.SetPoint( i, v(pos.x, pos.y + 40*t.y*-1, pos.z)) # Upper spline
                          a += 1
                          if a == 4:
                              a = 0
                      sh.FreeSpline()
                      return myHelix
                    On 12/09/2015 at 08:06, xxxxxxxx wrote:
                    Indeed, great work!
                    Thanks for sharing.
                    And I agree with you, it is sometimes frustrating, but most of the time great fun!
                    -Pim
                      On 29/09/2015 at 07:46, xxxxxxxx wrote:
                      Now I realize why this thread hasn't been closed.  Perhaps the moderators realize that they would just be spoiling our fun solving our puzzles if they offered fixes to obvious mistakes?  I dunno, but this has been a fun puzzle.  Of course completed I see how simple it is.  After finally getting around to using this function in a plugin outside of my simple flat test scene, I found out that it didn't work correctly, with the dreaded flattening out of my helix at some locations.  Here is my corrected code, which has at least worked on a couple other test splines bending in all directions:
                      # seg = (spLen/stitchAmount)/(16*wrapNum)
                      # offSet = 0
                      # rad is the radius of the helix
                      # wrapNum is the number of times the helix will wrap around my spline
                      # stitchAmount is the number of spline "stitches" to make
                      # spLen = sh.GetSplineLength()
                      for i in range((16*wrapNum)*stitchAmount) :
                                  cn = sh.GetCrossNormal(offSet)
                                  if a == 0:
                                      myHelix.SetPoint( i, v(pos.x - rad*cn.x, pos.y - rad*cn.y, pos.z - rad*cn.z)) # Inward spline
                                  if a == 1:
                                      myHelix.SetPoint( i, v(pos.x + rad*t.x, pos.y + rad*t.y, pos.z + rad*t.z)) # Lower spline
                                  if a == 2:
                                      myHelix.SetPoint( i, v(pos.x + rad*cn.x, pos.y + rad*cn.y, pos.z + rad*cn.z)) # Outward spline
                                  if a == 3:
                                      myHelix.SetPoint( i, v(pos.x - rad*t.x, pos.y - rad*t.y, pos.z - rad*t.z)) # Upper spline
                                  a += 1
                                  a %= 4
                        On 29/09/2015 at 07:54, xxxxxxxx wrote:
                        Yeah, we would never want to spoil the fun of our community 😉
                        Usually we leave threads open for a few more days (especially on open discussions like this) to see, if there are any follow up questions. And to be honest I lacked the time to check for "closeable" threads during the last weeks.
                        Anyway, good to see you have fun and come up with optimized solutions. Please forgive my laziness.
