    detect auto keyframing is on? [SOLVED]
    7 Posts 0 Posters 651 Views
      On 03/04/2015 at 04:30, xxxxxxxx wrote:
      Hi all,
      I was wondering if there is some line of code that allows me to detect if automatic keyframing is turned on. Does anybody know? I've searched through the python documentation but I can't seem to find it. Thanks in advance!
        On 03/04/2015 at 06:23, xxxxxxxx wrote:
        I looked up the Plugin ID of the Autokeying command in the "Customize Commands..." window.
        ID_AUTOKEYING = 12425
        print c4d.IsCommandChecked(ID_AUTOKEYING)
        Niklas
          On 03/04/2015 at 06:33, xxxxxxxx wrote:
          Thanks for the reply!
          However, it doesn't seem to work in a python node in Xpresso. When I put in the code like this:
              global Output1
              Output1 = 1
          It keeps printing False after I turned autokeying on. Any thoughts?
          Grtz!
            On 03/04/2015 at 07:19, xxxxxxxx wrote:
            Executing commands [via CallCommand()] is restricted to the main thread (and expressions are executed in their own thread). Maybe this applies to IsCommandChecked() as well.
              On 03/04/2015 at 07:28, xxxxxxxx wrote:
              Ok, I'll try a different approach. Thanks for the info!
                On 07/04/2015 at 06:38, xxxxxxxx wrote:
                just want to confirm that Niklas is right, these have to be called from main thread.
                  On 21/04/2015 at 06:57, xxxxxxxx wrote:
                  Hi hanswillem,
                  did you find a solution?
