    Pointer coordinates inside a UserArea [SOLVED]
    3 Posts 0 Posters 366 Views
      On 01/04/2015 at 14:39, xxxxxxxx wrote:
      I have the following code:
           def Message(self, msg, result) :
                if msg.GetLong(c4d.BFM_INPUT_CHANNEL)==c4d.BFM_INPUT_MOUSELEFT:
                     # the mouse is being pressed
                     self.dragging=True
                     mouseX1=msg.GetLong(c4d.BFM_INPUT_X)
                     mouseY1=msg.GetLong(c4d.BFM_INPUT_Y)
                     localPos=self.Global2Local()
                     self.i_x1=mouseX1+localPos['x']
                     self.i_y1=mouseY1+localPos['y']
                     while True:
                          # dragging the mouse
                          bc = c4d.BaseContainer()
                          if gui.GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSELEFT, bc) :
                               if bc.GetLong(c4d.BFM_INPUT_CHANNEL)==c4d.BFM_INPUT_MOUSELEFT:
                                    mouseX2=bc.GetLong(c4d.BFM_INPUT_X)
                                    mouseY2=bc.GetLong(c4d.BFM_INPUT_Y)
                                    self.i_x2=mouseX2+localPos['x']
                                    self.i_y2=mouseY2+localPos['y']
                                    self.Redraw()
                                    if not bc.GetBool(c4d.BFM_INPUT_VALUE) : break
                     self.dragging=False
                return gui.GeUserArea.Message(self, msg, result)
      The starting coordinates (stored in i_x1 and i_y1) are calculated correctly.
      But the coordinates of the pointer while the mouse button is being pressed (stored in i_x2 and i_y2) are not being calculated correctly. However I'm using the exact same method to calculate both.
      If I use Screen2Local instead of Global2Local (in the calculations of the coordinates while the mouse button is being pressed), the i_x2 coordinate is calculated correctly but the i_y2 coordinate has a negative displacement.
      Can't they be calculated the same way?
      Please, please, please, someone help me.
        On 01/04/2015 at 14:43, xxxxxxxx wrote:
        Ok, solved it!!! 😄
        It was fast.
        I just replaced the:
        with
        if self.GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSELEFT, bc) :
          On 02/04/2015 at 03:24, xxxxxxxx wrote:
          You should do this in InputEvent(), not Message()
