    Connect to node ports?
    5 Posts 0 Posters 853 Views
      On 13/01/2003 at 07:54, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      Language(s) :     C++  ;  XPRESSO  ;
      how to connect two node ports? I tried it like this:
      GvPort* bornshape = born->AddConnection(born,born->GetOutPort(0),shape,shape->GetInPort(0)); if(!bornshape) return FALSE;
      and it seems to work but they aren´t connected anyway :
      Do I have to do anything with the returned GvPort?
      P.S.: When there is a port output of (the description) type TP_Particle, how can I store it in a variable? What datatype is that?
        On 30/03/2006 at 17:10, xxxxxxxx wrote:
        Did you every figure this out? I am having an identical issue. Know nothing of how this is all supposed to work and be configured and each progressive inch is a Battles of the Nodes.
        In my case, there are three nodes - two Object nodes with slider ports and an intervening RangeMapper node.
          On 31/03/2006 at 05:39, xxxxxxxx wrote:
          I have confirmed that the naive approach of just doing
              GvNode* n1u = NULL;
              GvNode* n2u = NULL;
              GvPort* p1u = NULL;
              GvPort* p2u = NULL;
              if (m->IsConnectionValid(n1, p1, n2, p2, n1u, p1u, n2u, p2u))
               n1->AddConnection(n1u, p1u, n2u, p2u);
          doesn't seem to work for me either with two object nodes and manually added ports. I'm investigating if there's a proper way to add connections.
            On 30/11/2008 at 06:26, xxxxxxxx wrote:
            Hi!
            1. Currently I have the same problem. I tried out to connect two ports, but they are not connected. What can I do?
            Thanks for your help.
              On 30/11/2008 at 07:26, xxxxxxxx wrote:
              It seems to work.
              > \> GvPort\* AddConnection(GvNode\* source_node, GvPort\* source_port, GvNode\* dest_node, GvPort\* dest_port); \>
              If source_port is the outport and dest_port is the inport, it does not work. If source_port is the outport, it works.
              Bye.
