    Make Editable example [SOLVED]
    25 Posts 0 Posters 16.3k Views
      On 02/04/2015 at 11:00, xxxxxxxx wrote:
      Hi Andreas,
      Your assumption about an object-generator plugin was right.
      First I should note that I copied the doublecircle-plugin and adjusted it to my needs, since I don't feel I have enough understanding to start from nothing. Because of doing that, I didn't add the function GetVirtualObjects(). Instead, I have GetContour (which is fine for me, because I start with a splinestar), who calls my other object generating functions. -> This could maybe cause the problem.
      Secondly I'm making this plugin for my company, so I can't give too much information about what the plugin needs to do. This said, I'm now working on adding a cube to the scene, giving it 2 segments in the Y-axis. After that, I want to place the points on specific locations, given by user input. (First to generate the object, and again inside Message for if the parameters are changed) Later on I will probably need to put a morph tag on it, which should behave differently on specific situations (probably set in Xpresso).
      This is also the reason I want direct access to the polygon object, probably something like this:
      BaseObject* res;
      PolygonObject* PolyCube;
          res = static_cast<BaseObject*>(mcd.result->GetIndex(0));
          polyCube = (PolygonObject * )res;
          if(!polyCube) goto Error;
      So I could use polyCube->GetPointCount(); etc...
      I hope this is enough information, if not, ask me for more!
      Again thanks in advance for your help and time!!
      Greetings,
      Casimir Smets
        On 07/04/2015 at 05:34, xxxxxxxx wrote:
        Hi Casimir,
        in my code inside
        if (SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT, cd))
        there you have the PolygonObject in cd.result->GetIndex(0).
        It is casted to BaseObject in order to return it properly.
        You can simply cast it to a PolygonObject* and from then use GetPolygonR() or GetPolygonW() to get the polygon array. And GetPointR() or GetPointW() to access the point array.
        pretty much like in your last piece of code.
          On 08/04/2015 at 08:53, xxxxxxxx wrote:
          Hi Andreas,
          Thanks for your answer!
          Still, with my experience, I thought it would be more simple to use the Make Editable command.
          So I did, and now I got it working (I've tried before, with less success).
          For the people wondering how I did it:
          BaseContainer* bb = op->GetDataInstance();
          BaseObject* cube = BaseObject::Alloc(Ocube);
          if (!cube)
            return nullptr;
          cube->SetName("Cube");
          cube->SetRelPos(Vector(4 + bb->GetInt32(WIDTH) / 2, 0, 0));
          BaseContainer* const bc = cube->GetDataInstance();
          bc->SetInt32(PRIM_CUBE_SUBY, 2);
          doc->InsertObject(cube, parent, NULL);
          doc->SetActiveObject(cube);
          CallCommand(12236);
          PolygonObject* polyCube;
          polyCube = (PolygonObject * )doc->GetActiveObject();
          Int32 pcnt = polyCube->GetPointCount();
          GePrint(String::IntToString(pcnt));
          //Used to check if the polygonobject got retrieved
          return polyCube;
          This method gets called inside GetContour (The same method as in DoubleCircle - SDK Example). That's also where I get my doc from.
          You can mark this post as SOLVED.
          Greetings,
          Casimir Smets
            On 09/04/2015 at 06:53, xxxxxxxx wrote:
            Hi Casimir,
            I need to comment on your solution, as what you are doing there is highly dangerous, actually it is forbidden.
            GetContour() is called in thread context and you are not allowed to do any changes to the scene in this context. Furthermore, I think, the solution (if it would work) is bad for the user, as you are changing the user's selection. Not any user will like this...
            Please note: Changing the active scene from a thread context may seem to work, but the consequences of this error may be manifold and really hard to track.
            I strongly suggest to use my code example. It's really not doing much different than yours, but it should be safe.
              On 10/04/2015 at 03:28, xxxxxxxx wrote:
              Hi Andreas,
              Thanks for your feedback!
              I'll try to do it the better (your) way.
              But what I'm wondering is, why is the method GetContour() used inside the DoubleCircle SDK example? Doesn't that give threading problems?
              Also, I'm changing the active object again after making it editable. The user also doesn't need to select any objects while working with my plugin, just sliders.
              Greetings,
              Casimir Smets
                On 10/04/2015 at 03:45, xxxxxxxx wrote:
                Hi Andreas,
                Another quick question: is GetContour() giving the big problem here? Or also the way I'm making my objects? Or is that a matter of personal preference and style?
                Thanks for your time and help!
                Greetings,
                Casimir Smets
                  On 10/04/2015 at 03:58, xxxxxxxx wrote:
                  the problem is to call CallCommand() and InsertObject() within GetContour().
                  GetContour() is called in a thread context, while CallCommand() and InsertObject() are not allowed to be used in a thread context.
                    On 10/04/2015 at 06:43, xxxxxxxx wrote:
                    Hi, me again 😉
                    We had some discussion about this thread in our team and perhaps I should add some more info.
                    First of all there's an article about threading in the SDK docs: Important Threading Information
                    Some more on GetContour(), the same is true for GetVirtualObjects() :
                    These functions are only thought to generate a spline or an object (these also may have childs) and then return these. Cinema 4D will handle all the integration into the scene. And as these are called in a thread context, you must never ever do any changes directly to the scene in these functions.
                    Finally I completely ignored the "PolygonObject in GetContour" problem. I'm wondering, what you are actually trying to do with this object in GetContour(), as you can't return it and are not allowed to insert it into the scene. The correct place to generate your PolygonObject would rather be GenerateVirtualObjects().
                      On 20/04/2015 at 07:50, xxxxxxxx wrote:
                      Hi Andreas,
                      Thanks for your information!
                      I've tried and tried, but without success.
                      Could you maybe provide me with a simple example on how to add a nullobject-child to the cube (parent).
                      Also, I'm not allowed to use InsertUnder() inside GetVirtualObjects, right? Or am I wrong?
                      Thanks for your help and time!
                      Greetings,
                      Casimir Smets
                        On 20/04/2015 at 08:52, xxxxxxxx wrote:
                        you may use InsertUnder() and alike inside GVO. But you are not allowed to make changes to the active scene (only your objects cache) with these functions during GVO. If you generate a cube in GVO, you are allowed to use InsertUnder() to insert a Null Object as child of the cube. And then later on you can return the cube as result from GVO.
                        You can simply check it. Just select your generator object and hit the c key. You will see the hierarchy you generated within the Object Manager.
                          On 20/04/2015 at 11:20, xxxxxxxx wrote:
                          Hi Andreas,
                          Unfortunately, that doesn't work with me. I've tried to add a sphere to the cube with InsertUnder, but nothing to see inside Cinema 4D. Could you please provide me with a simple example on how to add a BaseObject to the cube? It doesn't matter which object.
                          Greetings,
                          Casimir Smets
                            On 20/04/2015 at 12:22, xxxxxxxx wrote:
                            I've finally got it to work, but now my next problem comes up. I have more than a few null objects inside my plugin, but when I make it editable/current state to object, it deletes that null objects, which is definately not what I want. Especially because some are helper objects for their childs.
                            Is there any way to let null objects stay after making something editable?
                            Greetings,
                            Casimir Smets
                              On 20/04/2015 at 12:26, xxxxxxxx wrote:
                              Allready found my own solution. If you have a null as child, it disappears when making editable/current state to object. If your null is a parent for another object (NOT NULL) it does not go away.
                              Greetings,
                              Casimir Smets
                                On 21/04/2015 at 12:06, xxxxxxxx wrote:
                                You can mark this as solved!
                                It works like the way Andreas showed on page 1.
                                Greetings,
                                Casimir Smets
