    Command function doesn't get called [SOLVED]
    7 Posts 0 Posters 628 Views
      On 23/03/2015 at 09:27, xxxxxxxx wrote:
      Cinema 4D Version:   R16
      Platform:      Mac OSX  ;
      I'm working on an object-plugin. I have implemented the method Command, but it seems it doesn't get called. Here is my method:
      Bool MyPluginData::Command(Int32 id, const BaseContainer &msg)
        if (id == HIPNULLPTR_POS_Y)
            GePrint("The slider is pressed!");
      return true;
      Did I do something wrong here? Or did I simply forget something?
      I've looked for hours on the internet, in the SDK, but still found no answer.
      Thanks for your help and time!
      Greetings,
      Casimir Smets
        On 23/03/2015 at 11:46, xxxxxxxx wrote:
        Mainly only buttons really trigger Command().  For other controls, you need to use Message().
          On 23/03/2015 at 17:44, xxxxxxxx wrote:
          And actually Command() is not a method of the ObjectData class, but GeDialog. If you want to notice
          when a value was changed, override Message() and catch the MSG_DESCRIPTION_* message that
          matches your needs.
          Best
          Niklas
            On 24/03/2015 at 06:31, xxxxxxxx wrote:
            Well, that did it, especially the MSG_DESCRIPTION. With my slider I needed the MSG_DESCRIPTION_CHECKUPDATE inside Message.
            You can mark this as closed!!
            Thanks for your help guys!! 🙂
            Greetings,
            Casimir Smets
              On 24/03/2015 at 06:52, xxxxxxxx wrote:
              Well, it worked when I had a simple GePrint. Now with some additional methods it doesn't work anymore.
              Here is my code in Message:
              if (type == MSG_DESCRIPTION_CHECKUPDATE)
                    BaseObject* op = (BaseObject* )node;
                    BaseDocument* doc = (BaseDocument* )data;
                    EditHipNullptr(op, doc);
                    GePrint("The slider is pressed! - CheckUpdate");
              And the code from EditHipNullptr:
              BaseObject* CharacterCreatorData::EditHipNullptr(BaseObject* op, BaseDocument* doc)
                BaseObject* hipNullPtr = doc->SearchObject("Hip_Nullptr");
                BaseContainer* bb = op->GetDataInstance();
                hipNullPtr->SetRelPos(Vector(0, bb->GetInt32(HIPNULLPTR_POS_Y), 0));
                hipNullPtr->Message(MSG_UPDATE);
                return hipNullPtr;
              When I change the slider in Cinema 4D, the application doesn't respond anymore.
              Does somebody have an idea what could be the problem here?
              Greetings,
              Casimir Smets
                On 24/03/2015 at 07:52, xxxxxxxx wrote:
                the data of MSG_DESCRIPTION_CHECKUPDATE is not a BaseDocument but of the type DescriptionCheckUpdate. In that structure you will find a pointer to the document.
                Also, you don't have any nullptr-checks in your code, so when SearchObject() fails it must crash.
                  On 24/03/2015 at 08:10, xxxxxxxx wrote:
                  Hi Sebastian,
                  That did it! Thank you very much!
                  I also changed my method for nullptr-checks.
                  You can surely mark this as closed now!
                  Greetings,
                  Casimir Smets
