    2 python effectors communicating [SOLVED]
    6 Posts 0 Posters 520 Views
      On 19/03/2015 at 11:03, xxxxxxxx wrote:
      Hello all,
      is it possible that 2 python effectors are exchanging data ?
      Example: the first effector will move clones while the second effector would stop them when the clones have reached the influence of the falloff of the second effector. How can I manage to signal the first effector to stop moving the clones ? I have tried to use global variables but this seems to work only inside the code of one effector. Another way would be user data, but how can I store a complete array (like the clones) as user data ?
      Would be great if anyone could give me any hint.
      regards,
      Jens
        On 19/03/2015 at 11:19, xxxxxxxx wrote:
        You can use the R16 CallFunction to communicate ( and pass around MoData Arrays) between Effectors. check out the SDK ( modules/c4d/index.html#c4d.CallFunction )
        d
          On 19/03/2015 at 11:44, xxxxxxxx wrote:
          Thanks a lot Douwe for your quick help !
          The R16 CallFunction sounds very promising ! I'm a bit confused after reading the parameter description for "op":
          op (BaseList2D) : the object to search the function within its script
          Hmm, which "object" is meant in case of effectors ?
          Maybe a little try and error will get me on the right track ...
          Thanks again for your help !
            On 20/03/2015 at 02:59, xxxxxxxx wrote:
            Hi Jens,
            In your case op for CallFunction() is the Python effector that holds the function to call within its embedded script.
              On 20/03/2015 at 12:45, xxxxxxxx wrote:
              Hi Yannick,
              ahh - now I get it.
              Have just tried it, works like a charm 🙂
              Thanks a lot !
                On 23/03/2015 at 01:34, xxxxxxxx wrote:
                Glad to help!
                I'll tag the topic as solved.
