    Bounding box after point manipulation [SOLVED]
    3 Posts 0 Posters 303 Views
      On 09/03/2015 at 13:41, xxxxxxxx wrote:
      Cinema 4D Version:   14,15,16
      Let's say that I have a polygonal object and I scaled its points without changing the object matrix. As a result, the bounding box is not affected by the scaling, and the object is unselectable outside the original bounding box (before the scaling).
      My question is how do I update the bounding box after the point scaling. I cannot scale the object matrix because I am doing some intricate point manipulation and not just scaling.
      I figured I would use MinMax, but I don't know how to apply it to the object.
      MinMax mm;
      const Vector *pPoints = ToPoint(op)->GetPointR();
      LONG i, numPoints = ToPoint(op)->GetPointCount();
      mm.Init();
      for(i=0; i<numPoints; i++)
      	mm.AddPoint(*pPoints);
              pPoints++;
      Now how do I make use of mm to update the bounding box of my polygonal object?
        On 09/03/2015 at 13:53, xxxxxxxx wrote:
        Regarding the unselectability, you should send MSG_UPDATE after you
        are done making changes to the object via its Message() method.
          On 09/03/2015 at 14:14, xxxxxxxx wrote:
          Thanks Niklas. That did the trick, and updated the bounding box as well.
