    How to return C4DNoise as Vector [SOLVED]
    2 Posts 0 Posters 287 Views
      On 07/03/2015 at 14:52, xxxxxxxx wrote:
      Cinema 4D Version:   14,15,16
      I need to return a Noise function as vector , and not as the default float. The reason is that I am using noise to deform an object, and I need it to affect the x, y and z axes.
      What I am currently using is this:
      Real rX = myC4dnoise->Noise(NOISE_NOISE, FALSE, padr[i], 0, 5 FALSE, 0, 0, 0);
      where padr are the point positions of the object.
      I can of course use a combination of different results to form a vector, but this does not result in the correct noise deformation.
      What I am trying to achieve is similar to a Displace Modifier that has a noise shader applied.
      So the question is how to return a noise function as a vector that has the correct x, y and z components representing the noise values in each dimension.
      Any help is greatly appreciated.
        On 07/03/2015 at 22:56, xxxxxxxx wrote:
        Answering my own question. The noise result should be used on the point normals, and not positions as I was previously doing.
