    user area - drop finished
    5 Posts 0 Posters 1.0k Views
      On 06/03/2015 at 12:06, xxxxxxxx wrote:
      I try to revive a drag and drop on a user area but I don`t get the finished
      def Message(self, msg, result) :
              if msg.GetId() == c4d.BFM_DRAGRECEIVE:
                  str = ""
                  type = 0;
                  object = None
                  bl = None
                  print "revice"
                  dragobject = self.GetDragObject(msg)
                  print dragobject
                  if msg.GetLong(c4d.BFM_DRAG_FINISHED) :
                      print "  info(Dropped..."
        On 09/03/2015 at 10:45, xxxxxxxx wrote:
        Drag and drop methods are not currently documented in GeUserArea and GeDialog but they are fully functioning. They will be documented in the near future.
        To receive drag and drop messages as expected it is important to return the appropriate values from Message() with SetDragDestination().
        Here is the code I added to the Py-MemoryViewer example:
          if msg.GetId()==c4d.BFM_DRAGRECEIVE:
            # Discard if lost drag or if it has been escaped
            if msg.GetInt32(c4d.BFM_DRAG_LOST) or msg.GetInt32(c4d.BFM_DRAG_ESC) :
              return self.SetDragDestination(c4d.MOUSE_FORBIDDEN)
            # Check drop area and discard if not on the user area
            if not self.CheckDropArea(msg, True, True) :
            print "Dragged"
            # Get drag object type and data
            draginfo = self.GetDragObject(msg)
            # Check if drag is finished (=drop)
            if msg.GetInt32(c4d.BFM_DRAG_FINISHED)==1:
              print "Dropped"
            # Return current mouse cursor for valid drag operation
            return self.SetDragDestination(c4d.MOUSE_MOVE)
          # Call GeUserAre.Message() implementation so that it can handle all the other messages
          return gui.GeUserArea.Message(self, msg, result)
        Note GetDragObject() returns a dictionary with 2 object "type" and "object" (in the code I prefer to assign these individually).
        MOUSE_POINT_HAND is returned for the current drag destination cursor but any other valid MOUSE value can be returned.
        EDIT: Updated code.
          On 09/03/2015 at 16:49, xxxxxxxx wrote:
          Thanks Yannick,
          work great
                if not gui.GeUserArea.CheckDropArea(self, msg, True, True) :
                print "Dragged"
                type, data = self.GetDragObject(msg)
                  print "Dropped"
            I just want to point out that it is not guaranteed that the dictionary will
            unpack in the order you expect it, so you should definetly assign type
            and data seperately.
            Also, you can (should) use self.CheckDropArea(...) instead of
            c4d.gui.GeUserArea.CheckDropArea(self, ...).
            Best regards,
            Niklas
              On 10/03/2015 at 02:02, xxxxxxxx wrote:
              Hi Niklas,
              unpack in the order you expect it, so you should definitely assign type
              and data separately.
              You're right. The code I posted doesn't actually unpack the drag object information dictionary from GetDragObject() as expected.
              Yes it's better and it looks nicer to call CheckDropArea() on self instead.
              I updated the code I posted yesterday.
