    Getting the Editor Color for a shader [SOLVED]
    6 Posts 0 Posters 615 Views
      On 04/03/2015 at 14:43, xxxxxxxx wrote:
      Cinema 4D Version:   15
      Platform:      Mac OSX  ;
      I was trying to create a shader that would return the editor display color of an object.
      My main shader code is this:
      Vector EditorColorShaderData::Output(BaseShader * chn, ChannelData * cd) {
      Vector the_color=Vector(.5,.5,.5);
          if (cd->vd)
                  RayObject *op = NULL;
      op= cd->vd->op;
                  if (op)
                     BaseObject* original=(BaseObject* ) op->link;
                     BaseContainer* bc=original->GetData()
                     if (bc) the_color=bc->GetVector(ID_BASEOBJECT_COLOR)
      return the_color;
      But it is not working. I mean, it always gets me a grey color (the default I set).
      How can I get the color of the editor of an object, at render time, in a shader?
        On 04/03/2015 at 23:35, xxxxxxxx wrote:
        Sounds like you need BaseObject::GetColorProperties().
          On 05/03/2015 at 03:12, xxxxxxxx wrote:
          I tried the following code:
          ObjectColorProperties* prop;
          original->GetColorProperties(prop);
          the_color=prop->color;
          But it is not working 😞
            On 05/03/2015 at 04:52, xxxxxxxx wrote:
            Your are passing an uninitialized pointer to GetColorProperties() so it can't fill it with data.
            Try this instead:
            ObjectColorProperties colorProps;
            original->GetColorProperties(&colorProps;);
            the_color = prop.color;
              On 05/03/2015 at 05:23, xxxxxxxx wrote:
              YES!!! Finally did it!
              Thank you all 😄
                On 05/03/2015 at 07:31, xxxxxxxx wrote:
                Thanks for helping Rui. I'll close this thread as solved.
