    Retrieving several Inport Data?
    6 Posts 0 Posters 971 Views
      On 07/01/2003 at 07:08, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      Language(s) :     C++  ;  XPRESSO  ;
      I tried to get the inport data of my plugin node but I can only retrieve the data of the first port. The second one is NULL. I tried two ways:
          GvPort* ipt = bn->GetInPort(1);
             GeData iptdata = GvGetPortGeData(bn, ipt, run);
             Vector pos = iptdata.GetVector();
             GvPort* inport = vinport->GetPort();
             GeData inportdata = GvGetPortGeData(bn, inport, run);
             Vector normale = inportdata.GetVector();
      the second one does give me the data of the first inport correctly. The first one doesn´t give me the data, though the port is correct and I can also get the name of the port. How can I get the data of several ports then?
      Samir
        On 08/01/2003 at 02:32, xxxxxxxx wrote:
        The ports must be calculated correctly. The easiest way is to always use the convenience functions for value tables. Please refer to this example: (And just add more ports to input_ids.)
            static LONG input_ids[] = { INPORT_LINK, 0 }; // Use this for the input ports!
            enum { INPORT_LINK_INDEX };
            class Node: public GvOperatorData
            // Defines super
            INSTANCEOF(Node, GvOperatorData)
              virtual Bool iCreateOperator(GvNode *bn)
                BaseContainer* data = bn->GetOpContainerInstance();
                if (!data) return FALSE;
                data->SetLong(STEPS, 3);
                return SUPER::iCreateOperator(bn);
              Bool InitCalculation(GvNode *bn, GvCalc *c, GvRun *r)
                return GvBuildInValuesTable(bn, ports, c, r, input_ids);
              void FreeCalculation(GvNode *bn, GvCalc *c)
                GvFreeValuesTable(bn, ports);
              Bool Calculate(GvNode *bn, GvPort *port, GvRun *run, GvCalc *calc)
                if (!port) return FALSE;
                BaseContainer *data = bn->GetOpContainerInstance();
                LONG steps = data->GetLong(STEPS);
                LONG mode = data->GetLong(MODE_ID);
                GvValue* vinport = ports.in_values[INPORT_LINK_INDEX];
                if (!vinport) return FALSE;
                if (!vinport->Calculate(bn, GV_PORT_INPUT, run, calc, 0)) return FALSE;
                BaseDocument* doc = bn->GetNodeMaster()->GetDocument();
                if (!doc) return FALSE;
                BaseLink* link = inportdata.GetBaseLink();
                if (!link) return FALSE;
                BaseList2D* list = link->GetLink(doc);
                if (!list) return FALSE;
                switch(port->GetMainID())
                case OUTPORT_LINK:
                    BaseObject* obj = static_cast<BaseObject*>(list);
                    for (LONG i = 0; list && i < steps; ++i)
                      switch(mode)
                      case GETDOWN: obj = obj->GetDown(); break;
                      case GETUP: obj = obj->GetUp(); break;
                      case GETPRED: obj = obj->GetPred(); break;
                      case GETNEXT: obj = obj->GetNext(); break;
                    AutoAlloc<BaseLink> bl;
                    if (!bl) return FALSE;
                    bl->SetLink(obj);
                    return GvSetPortGeData(GeData(bl), bn, port, run);
                return FALSE;
              static NodeData* Alloc(void) { return gNew Node; }
            private:
              GvValuesInfo ports;
          I am already doing this.
          static LONG input_ids[] = { NORMAL,0,LEAVECOUNT,1}; // Use this for the input ports!
          and then the same procedure as shown in your example above.
          here is some code then in my calculate method
                 BaseContainer *data = bn->GetOpContainerInstance();    if (!data) return FALSE;
                 LONG offsetseed = data->GetLong(OFFSET_SEED);
                 LONG offset = data->GetLong(OFFSET);
                 Random rnd;
                 rnd.Init(offsetseed);
                 GvValue* vinport = ports.in_values[INPORT_LINK_INDEX];    if (!vinport) return FALSE;
                 if (!vinport->Calculate(bn, GV_PORT_INPUT_OR_GEDATA, run, calc, 0)) return FALSE;
                 /*LONG portcnt = bn->GetInPortCount();
                 Vector pos = iptdata.GetVector();  */
          The problem is that I cannot get the second port with vinport->GetPort().
          This only returns the first inport. GetPort() should take a SubID parameter for the inport afaik
          but that doesn´t work either.
          Am I missing something? :\
            On 10/01/2003 at 02:03, xxxxxxxx wrote:
            Any conclusions yet?
              On 11/01/2003 at 07:03, xxxxxxxx wrote:
              Uhm, input_ids is supposed to be zero terminated. So you should have:
                  static LONG input_ids[] = { NORMAL,LEAVECOUNT,0};
                  enum { INPORT_NORMAL_INDEX, INPORT_LEAVECOUNT_INDEX };
              Then you repeat the whole ports.in_values part for each port.
                On 11/01/2003 at 07:46, xxxxxxxx wrote:
                oh, ok. Works just fine now.
                P.s.: Mikael works at the weekend? 🙂
