    resolve an instance object [SOLVED]
    5 Posts 0 Posters 597 Views
      On 19/02/2015 at 13:43, xxxxxxxx wrote:
      Hi all,
      I try to apply the command "current state to object" to an Instance so that it is a new polygon-object.
      But something is going wrong :-(((
      Can anybody give me an advice how to convert an Instance please.
      def resolve_all_Instance_Objects(doc) :
          doc.SetActiveObject(None)
          obj = doc.GetFirstObject()
          instance_list = []
          while obj:
              if obj.CheckType(c4d.Oinstance) :
                  print 'Instanobjekt gefunden'
                  instance_list.append(obj)
              obj = walk(obj)
          print instance_list
          for obj in instance_list:
              settings = c4d.BaseContainer()
              settings.SetBool(c4d.MDATA_CURRENTSTATETOOBJECT_INHERITANCE, True)
              settings.SetBool(c4d.MDATA_CURRENTSTATETOOBJECT_KEEPANIMATION, True)
              settings.SetBool(c4d.MDATA_CURRENTSTATETOOBJECT_NOGENERATE, True)
              new_object = c4d.utils.SendModelingCommand(c4d.MCOMMAND_CURRENTSTATETOOBJECT, list = [obj.GetClone()], bc=settings, doc=doc)
              #obj.remove()
              doc.InsertObject(new_object[0])
              print 'new_object'
      thanks a lot to all
        On 19/02/2015 at 15:07, xxxxxxxx wrote:
        the no generator flag needs to be set to False.
        Best wishes
        Martin
        settings.SetBool(c4d.MDATA_CURRENTSTATETOOBJECT_NOGENERATE, False)
          On 20/02/2015 at 01:13, xxxxxxxx wrote:
          Thanks to you.
          It works.
          But another problem grows up.
          The instances are set as c4d.INSTANCEOBJECT_RENDERINSTANCE=True
          But I have to set them to c4d.INSTANCEOBJECT_RENDERINSTANCE=False
          I did a look to the SDK but didn't find anything about INSTANCEOBJECT_RENDERINSTANCE.
          So I think it is a general thing who to set a Value in BaseObject !?!
          So Question: Whow can I set the value to False?
          Thanks a lot
            On 20/02/2015 at 02:03, xxxxxxxx wrote:
            I´m glad I could help.
            The next problem....
            like almost every attribute an object has.
              obj[c4d.INSTANCEOBJECT_RENDERINSTANCE] = False
            or the other way like
              data = op.GetDataInstance()
              data.SetBool(c4d.INSTANCEOBJECT_RENDERINSTANCE, False)
            Best wishes
            Maritn
              On 20/02/2015 at 03:47, xxxxxxxx wrote:
              Thanks a lot.
              It solved my Problem.
              Ronald
