    Example for polygonizing an object tree [SOLVED]
    3 Posts 0 Posters 398 Views
      On 13/02/2015 at 16:55, xxxxxxxx wrote:
      Cinema 4D Version:
      Language(s) :
      Hi!
      I've been spending the last 1 hour searching for the example I remember only slightly from the
      C++ documentation that shows how recursively traverse the object tree and reading all the polygonal
      caches from generator objects, etc. but I just can not find it any more.
      It took care of excluding objects that are being used as input objects by generators. The problem I am
      having with this is, that the BIT_CONTROLOBJECT bit seems to be set not only on objects that have
      been touched by a generator object, but also on the generator object itself, making it indistinguishable
      for me whether a generator object is just generating, or is also the input object of another generator.
      Anybody remember where that snipped is hiding?
      Thanks 🙂
        On 14/02/2015 at 00:10, xxxxxxxx wrote:
        Hi Niklas,
        maybe it's this piece of code in the BaseObject::GetCache() description?
          On 14/02/2015 at 05:50, xxxxxxxx wrote:
          How on earth could I overlook it? I was even checking GetDeformCache().
          Thank you, Andreas 🍺
