    Custom Helix Spline Y_Movement [SOLVED]
    5 Posts 0 Posters 664 Views
      On 13/02/2015 at 01:03, xxxxxxxx wrote:
      I have this script for my own Helix spline:
      spl_A = doc.SearchObject("Spline_01")
          spl_pntC = 36
          spl_start = c4d.Vector (100.0, 0.0, 0.0) # Spline Size
          pnt_rad = utils.Rad((360.0 + 10.0) / spl_pntC)
          spl_end = c4d.Vector(0.0, 1.0, 0.0) #Movement
          spl_A.SetPoint (0,spl_start)
          spl_A.ResizeObject(spl_pntC)
          for id in xrange(1,spl_pntC) :
              spl_start = utils.MatrixRotY(pnt_rad) * utils.MatrixMove(spl_end) * spl_start
              spl_A.SetPoint(id, spl_start)
          spl_A[c4d.SPLINEOBJECT_TYPE] = c4d.SPLINETYPE_AKIMA
          # Spline does not close
          spl_A[c4d.SPLINEOBJECT_CLOSED] = False
          # Update of object
          spl_A.Message (c4d.MSG_UPDATE)
      I have a problem with my "MatrixMove" part. It does do what it is suppose to but I want to read it in cm eg: 21cm and not the matrix data. How would I do that 😊
      I want to adjust the height up and down with a control
      Thanks for any help
        On 13/02/2015 at 02:31, xxxxxxxx wrote:
        it´s already there.
        your spl_end variable gives you units in centimeters.
        c4d.Vector(0.0, 10.0, 0.0)  is 10 cm hight.
        If your object should be 360 cm high you´ll need 37 points (because the first one is 0)
        Keep in mind that your spline interpolation method add´s some hight to the bounding box, too.
        With e.g. linear interpolation you´ll get exactly 360 cm at 37 points.
        Best wishes
        Martin
          On 13/02/2015 at 02:50, xxxxxxxx wrote:
          Hi Martin.
          This "c4d.Vector(0.0, 10.0, 0.0) " does not give me a 10cm height as you stated but give me a height of 350 cm.
          Is there maybe another way to re-script this so that I can get a accurate height reading.
            On 13/02/2015 at 03:00, xxxxxxxx wrote:
            this is your step vector you multiply it for every x in xrange in the script so:
            Let´s say 37 steps -> spl-pntC = 37
            the first one is at 0.0 height.
            36*10 = 360 cm
            if you want 10 cm at the end how is your step size than?
            your step size should be 10/36.
            easy I guess
            hope this helps
              On 13/02/2015 at 04:09, xxxxxxxx wrote:
              Geez, thanks Martin 👏
              As simple as that 😊
