    Dis-/Enable UserData
    6 Posts 0 Posters 619 Views
      On 29/01/2015 at 02:36, xxxxxxxx wrote:
      I've got the small problem of not understanding the GetDEnabling(....) function.
      I wan't to dis-/enable a UserData field, currently working with "[c4d.DESC_HIDE]" provided by the forum here.
      This is my small code in a PythonNode:
        UD = myObject.GetUserDataContainer() #myObject is a link from the current object holding the UserData information
        for descId, container in UD:
            if descId[1].id == 2:
                container[c4d.DESC_HIDE] = Input1 #Input1 is the result of a Checkbox in the same UserData
                myObject.SetUserDataContainer(descId, container)
      Now I "just" want to change hide into disable, but that seems to be a bigger problem?
        On 29/01/2015 at 06:48, xxxxxxxx wrote:
        Hi ,
        '''Edit
        didn´t read carefully sorry for that...
        please look at this thread:
        ~~https://developers.maxon.net/forum/topic/8350/10900_pluginsobjectdata-enablegadget-solved
        Best wishes
        Martin
          On 29/01/2015 at 07:47, xxxxxxxx wrote:
          GetDEnabling() has to be implemented in an ObjectData plugin to enable/disable user data of the object. It cannot be used to enable/disable user data on other objects.
            On 30/01/2015 at 03:07, xxxxxxxx wrote:
            and there is no way around this problem? Any ideas?
              On 30/01/2015 at 09:09, xxxxxxxx wrote:
              I'm afraid there's no workaround for this.
                On 03/02/2015 at 21:26, xxxxxxxx wrote:
                If I understand you correctly you want to enable/disable an object??
                This is for a Cube, maybe this will put you on the right track.
                    obj = doc.SearchObject("Cube")
                    obj[c4d.ID_BASEOBJECT_GENERATOR_FLAG,] = False
