    Hierarchy problem :-(
    3 Posts 0 Posters 788 Views
      On 22/12/2002 at 10:58, xxxxxxxx wrote:
      Cinema 4D Version:   8.014
      Platform:    Mac  ;
      Well, let's see if I can explain this in a simple way:
      I have a routine that goes through all objects in a document, recursively (thank you Mikael for it 😉
      Each object that matches a criteria is affected by an action.
      My problem is when the action is deleting the objects
      If two objects in a row (meaning one following another) meet the criteria, only the first one is deleted.
      I believe this is due to the fact that the recursive routine calls the deletion routine and the next thing it does it to recursively call itself with object->GetNext( ), so it skips one object.
      I tried doint a conditional reculsive call with just object (no ->GetNext( )) whenever the action is deletion but I get stack overflows.
      Can anyone help me?
      I can provide a listing.
      Thank you very much in advance.
      Rui Batista
        On 24/12/2002 at 01:26, xxxxxxxx wrote:
        Ok, I solved it.
        I believe this is not the most elegant method (and not the fastest) but it works.
        To anyone else who encounters such a problem I explain my solution:
        I created an empty string to which I add the name of each object I need to delete, followed by a non-ASCII character, as a separator.
        After creating the string, one cycle removes each name from inside the string and performs a FindObject( ) for it and consequent object->Remove( ). The cycle goes on until the string is empty.
        Not elegant, but it works 😉
        Rui Batista
          On 24/12/2002 at 04:41, xxxxxxxx wrote:
          Was this a cruel way to make me reply? I cannot let such a "solution" pass by unchallenged... 😉
          This is a basic tree traversal problem. Unless I've misunderstood what you're doing, it should be trivial to modify David's code:
              ProcessHierarchy(obj)
                while(obj)
                  var next = obj->GetNext();
                  if (IsToBeDeleted(obj))
                    obj->Remove();
                  else
                    ProcessHierarchy(obj->GetDown());
                  obj = next;
