    saving/loading data in iCustomGui [SOLVED]
    SDK Help
    0
    • H
      On 28/01/2015 at 08:11, xxxxxxxx wrote:
      Cinema 4D Version:   13+
      _<_n_<_o_>__
      I have a lot of data which are inside a GeUserArea sub class, the data is dynamic "lots of pointers, vectors of pointers, ..."
      example:
      class myNodeUserArea : public GeUserArea
      private:
      	std::vector<mNode*> nodes;
      	std::vector<mWire*> wires;
      I'm not sure where to "put" these data so they can be saved/loaded easily, for example in the iCustomGui class, also I'm not sure how the TriState<> is loading and saving data
      right now I can add my custom data type from userdata, display it with my custom gui, modify the user area stuff, once I change any thing in the ui the user area becomes empty!! "as if I just created it without any modification"
      • H
        On 28/01/2015 at 14:15, xxxxxxxx wrote:
        _<_n_<_o_>__update: inside CustomGuiDat_<_o_<_o_>_a_<_n_<_o_>__/_<_o_<__<_o_<_o_>_>
        <_<_n_<_o_>__o>
        virtual CDial_<_o_<__<_o_<_o_>_Alloc(c_<_n_<_o_>__ B_<_o_<__<_o_<_o_>_ontaine_<_n_<_o_>__p; settings);
        [/C_<_o_<_o_>_
        is called every time the layout gets changed "a nightmare!!" ,
        so how can I store my data between draws, I see 2 examples which somehow stores a si_<_n_<_o_>__ data "tristate example for Niklas & custom slider example for Scotta"
        not sure how and where is this TriState is holding the data "after all every Alloc create_<_o_<_o_<_o_<__<_o_<_o_>_ew class which should contain a fresh TriState, pretty confusing_<_o_<_o_>_p;:nauseated_face: "
        • H
          On 29/01/2015 at 08:28, xxxxxxxx wrote:
          a GeUserArea and a custom GUI are exactly this – GUI elements that should display data but are not in charge of saving data.
          You can store custom data in a custom datatype. To be sure that the data is correctly written, read and copied overwrite WriteData(), ReadData() and CopyData(). You could write your data to the Hyperfile using a BaseContainer and WriteContainer()[URL-REMOVED] (depending on your data).
          The data is handed over to your custom GUI in SetData()[URL-REMOVED]. To get custom data simple read the value of the Tristate via GetValue()[URL-REMOVED] and then get the custom data type with GetCustomDataType()[URL-REMOVED]. When you change the data in your custom GUI you have to update the parent that the data was changed. This has to be done with a message:
          BaseContainer m(BFM_ACTION);
          m.SetInt32(BFM_ACTION_ID, GetId());
          m.SetData(BFM_ACTION_VALUE, GeData(MYCUSTOMDATATYPE, data));
          SendParentMessage(m);
          • H
            On 29/01/2015 at 08:48, xxxxxxxx wrote:
            Hi Sebastian,
            thanks for the help, I kinda understand now how to work it out 🙂, you are great.
            • H
              On 29/01/2015 at 17:34, xxxxxxxx wrote:
              well I tested, kinda works but there is a missing part in the chain "tristate sets data, gets data, but data is reset or not saved"
                  virtual Bool SetData(const TriState<GeData>& tristate) {
              		GePrint("TriState SetData()");
              		GePrint("setdata m_ua count " + String::IntToString(m_ua.count));
              		const GeData& value = tristate.GetValue();
              		if(!value.GetCustomDataType(23123123))
              			return FALSE;
              		iExampleDataType* mdata = static_cast<iExampleDataType*> (value.GetCustomDataType(23123123));
              		m_ua.count = mdata->count;
              		GePrint("setdata mdata count " + String::IntToString(mdata->count));
                  virtual TriState<GeData> GetData() {
              		GePrint("TriState GetData()");
              		Int32 count = m_ua.count;
              		GePrint("getdata count " + String::IntToString(m_ua.count));
              		iExampleDataType a;
              		a.count = count;
              		return TriState<GeData>(GeData(23123123, static_cast<CustomDataType> (a)));
              and here is the print of a simple variable "initialized to 1"
              TriState GetData()
              getdata count 2
              msg count 2 #making sure that the msg is correct
              TriState SetData()
              setdata m_ua count 2
              setdata mdata count 1 #bam!!! why it reads 1 not 2
              • H
                On 30/01/2015 at 00:26, xxxxxxxx wrote:
                such a behavior could be caused by the absence or incorrect implementation of a function in your datatype class. For example it is also important to correctly implement the Compare()[URL-REMOVED] function.
                • H
                  On 30/01/2015 at 03:23, xxxxxxxx wrote:
                  wow Sebastian!! , you nailed it from the first shot 👏, thanks again for the help.
