    Render Options [SOLVED]
    5 Posts 0 Posters 520 Views
      On 22/01/2015 at 07:52, xxxxxxxx wrote:
      I would like to create automatic setup render, with Effect (Ambient Occlusion, GI, Sketch and Toon) by Python
      I have not found in the SDK documentation
      Could you help me?
      Thank You
        On 22/01/2015 at 14:28, xxxxxxxx wrote:
        Example:
        How do I create a new "My Render Setting" with Sketch and Toon?  🙂
          On 22/01/2015 at 15:41, xxxxxxxx wrote:
          You are going to want to look at pvp and RenderData, this should help you out[URL-REMOVED].
            On 23/01/2015 at 06:20, xxxxxxxx wrote:
            as Shawn pointed out, render settings are stored with RenderData[URL-REMOVED] objects. You can create such an object and add it to your document. The RenderData object stores also a list of post effects; to add a post effect you have to create such an object and add it to the RenderData:
            # create new render settings
            renderData = c4d.documents.RenderData()
            if renderData is None:
            renderData.SetName("My New Render Settings")
            # create S&T post effect
            stVideoPost = c4d.BaseList2D(1011015)
            if stVideoPost is not None:
              # setup the video post
              stVideoPost[c4d.OUTLINEMAT_LINE_OUTLINE] = True
              # add video post to render data
              renderData.InsertVideoPost(stVideoPost)
              # add render data to document
              doc.InsertRenderData(renderData)
              # make active
              doc.SetActiveRenderData(renderData)
            The ID's of the post effects can be found in the ge_prepass.h and c4d_videopostdata.h header files; if such an ID cannot be found there you may have to create the post effect in question yourself and use above infrastructure to get the type via GetType()[URL-REMOVED].
              On 23/01/2015 at 14:02, xxxxxxxx wrote:
              thanks to all!!! 🙂
