    Accessing a MySQL database with python
    7 Posts 0 Posters 706 Views
      On 18/01/2015 at 10:35, xxxxxxxx wrote:
      Is it possible?
      Are there any libraries available?
      My MySQL database is online.
        On 19/01/2015 at 01:16, xxxxxxxx wrote:
        Have you tried this? : https://pypi.python.org/pypi/MySQL-python/1.2.5
        Haven't tried it but is supposed to be ok.
        -b
          On 19/01/2015 at 01:36, xxxxxxxx wrote:
          I found that but to include that in my plugins I would have to force users to install that, isn't it?
            On 23/01/2015 at 17:44, xxxxxxxx wrote:
            Hi Rui,
            Check out Niklas' C4D Tools
            There he mentions this bit of code:
            # Store the old module configuration.
            old_modules = sys.modules.copy()
            # Import your stuff, for example:
            lib_path = os.path.join(os.path.dirname(__file__), 'lib')
            sys.path.insert(0, lib_path)
            try:
                import c4dtools
            finally:
                sys.path.pop(0)
            # Restore the previous module configuration making sure to not
            # remove modules not loaded from the local libraries folder.
            for k, v in sys.modules.items() :
                if k not in old_modules and hasattr(v, '__file__') or not v:
                    if not v or v.__file__.startswith(lib_path) :
                        sys.modules.pop(k)
                    sys.modules[k] = v
            res, _ = c4dtools.prepare(__file__, __res__)
            You should be able to put the MySQL library in a lib folder next to your source file, and import it using something like the above code.
              On 23/01/2015 at 17:55, xxxxxxxx wrote:
              Hey,
              C4dtools is old, I should update it some time. 🙂 Today, I prefer to paste this snippet into my plugin:
              > import os, sys, glob
              > class localimport(object) :
              > _modulecache = []
              > _eggs = staticmethod(lambda x: glob.glob(os.path.join(x, '*.egg')))
              > def __init__(self, libpath, autoeggs=False, isolate=False, path=os.path) :
              > if not path.isabs(libpath) :
              > libpath = path.join(path.dirname(path.abspath(__file__)), libpath)
              > self.libpath = libpath; self.autoeggs = autoeggs; self.isolate = isolate
              > def __enter__(self) :
              > self._path, self._mpath = list(sys.path), list(sys.meta_path)
              > self._mods = frozenset(sys.modules.keys())
              > sys.path.append(self.libpath)
              > sys.path.extend(self._eggs(self.libpath) if self.autoeggs else [])
              > def __exit__(self, *args) :
              > sys.path[:] = self._path; sys.meta_path[:] = self._mpath
              > for key in sys.modules.keys() :
              > if key not in self._mods and self._islocal(sys.modules[key]) :
              > localimport._modulecache.append(sys.modules.pop(key))
              > def _islocal(self, mod) :
              > if self.isolate: return True
              > filename = getattr(mod, '__file__', None)
              > if filename:
              > try: s = os.path.relpath(filename, self.libpath)
              > except ValueError: return False
              > else: return s == os.curdir or not s.startswith(os.pardir)
              > else: return False
              And then use it like this:
              > with localimport('relative/path/to/lib/folder') :
              > import some_package
              You can always find the newest version in this gist.
                On 24/01/2015 at 03:36, xxxxxxxx wrote:
                So, with this code I could import the mysql library that would reside in a folder inside my plugin folder?
                  On 24/01/2015 at 07:38, xxxxxxxx wrote:
                  Yes, if you put the mysql lib in a libs folder at the same level as your plugin's code you should be able to import the MySql library using the above code.
