    3x3 matrix
    5 Posts 0 Posters 1.1k Views
      On 14/01/2015 at 04:24, xxxxxxxx wrote:
      Is there a way to do 3x3 matrix calculation like inverse mat.
      I like to use it, to calculate the intersection of a line and a plane.
      This problem is typically solved by expressing it in matrix form, and inverting it:
       begin{bmatrix} t  u  v end{bmatrix} = begin{bmatrix} x_a - x_b  x_1 - x_0  x_2 - x_0  y_a - y_b  y_1 - y_0  y_2 - y_0  z_a - z_b  z_1 - z_0  z_2 - z_0 end{bmatrix}^{-1} begin{bmatrix} x_a - x_0  y_a - y_0  z_a - z_0 end{bmatrix}.
      -Pim
        On 14/01/2015 at 06:32, xxxxxxxx wrote:
        you can invert a Matrix[URL-REMOVED] with "\__invert\_\_()[URL-REMOVED]" or the Python "invert" operator "~" .
        inverseMatrix = ~worldSpaceCoords
        You may also take a look at the GeRayCollider [URL-REMOVED]that can be used to calculate the intersections of a ray and a poly object.
          Yes, but that is all for a cinema 4d matrix and that is a 4x4 matrix, not a 3x3 matrix.
          I want to use a 3x3 matrix.
          I know I can use the GeRayCollider, but I want to do it myself.
          So, how to do 3x3 matrix calculations in cinema 4d?
          -Pim
            On 15/01/2015 at 06:55, xxxxxxxx wrote:
            if you cannot use the existing classes and functions of the API you have to solve this problem like any other problem by implementing your own solution or using a existing library.
            If you want to calculate the intersection of a ray and a triangle you do not necessarily need to handle Matrix objects. There are other algorithms like this one.
              On 15/01/2015 at 07:25, xxxxxxxx wrote:
              Thanks, i will make my own 3x3 matrix calculation.
              Thanks for the link.
