    Hirarchy search
    11 Posts 0 Posters 1.6k Views
      On 20/12/2002 at 19:18, xxxxxxxx wrote:
      Cinema 4D Version:   8.014
      Platform:    Mac  ;
      How can I create a recursive routive that goes through ALL objects in a document?
      I want to go through ALL... even all children.
      Thank you very much in advance.
      Rui Batista
        On 21/12/2002 at 00:45, xxxxxxxx wrote:
        Do you remember SpeeDisplay? and the tag issue? 🐵 this code below?
            GetActiveTagR(op)
             while (op)
              var atag=GetActiveTag(op);
              if (atag)
               return (atag);
              atag=GetActiveTagR(op->GetDown());
              if (atag)
               return atag;
              op=op->GetNext();
             return NULL;
            GetActiveTagA(doc)
             return GetActiveTagR(doc->GetFirstObject());
            main(doc,op)
             var atag=GetActiveTagA(doc);
             if (atag)
              var ob=atag->GetObject();
              println("Active Tag on Object "+ob->GetName());
        That is also how to do this one 😉
        The GetActiveTagR function recursively looks for an active tag, you can change it to find anything you like, or do anything you want 🐵
          On 21/12/2002 at 01:39, xxxxxxxx wrote:
          Also note that recursion cannot handle arbitrarily deep object hierarchies, so if you get stack problems you can search for GetNextHierarchyObject() in the forum archives for a non-recursive function.
            On 21/12/2002 at 04:03, xxxxxxxx wrote:
            Is that a COFFEE only problem? never had any stack issues with C++, how deep are they likely to be! or is that just "in theory"?
              On 21/12/2002 at 05:36, xxxxxxxx wrote:
              What do you mean by "arbitrarily deep object hierarchies", Mikael?
              Oh, and thank you for the listing again 😉 I didn't knew that handling objects could be done in the same way 🙂
              Rui Batista
                On 21/12/2002 at 05:40, xxxxxxxx wrote:
                Oh, and about GetNextHierarchyObject()... where are the forum archives?
                Rui Batista
                  On 21/12/2002 at 06:00, xxxxxxxx wrote:
                  If lets say some bizarre person create nest of maybe a million objects, say, like:
                  Obj 1
                     - Obj 2
                        - Obj 3
                           - Obj 4
                                 - Obj 1 million
                  then using a recursive function will run into problems with the stack (run out of the allocated memory for it basically).
                  Can't say I've ever thought about how deep it is safe to go, is there a known limit on the depth of children?
                    On 21/12/2002 at 07:19, xxxxxxxx wrote:
                    This was more of a problem in early C.O.F.F.E.E., and especially with the naive doubly recursive traversal (i.e. along siblings as well). I believe the limit was about 80 levels there, which was then doubled in R6 if I remember correctly. So you singly recursive function is probably safe for most things.
                    Oh, and for the archive impaired, here's GetNextHierarchyObject() :
                        GetNextHierarchyObject(obj, stopAt)
                          if (!obj) return NULL;
                          var next;
                          if (next = obj->GetDown()) return next;
                          if (next = obj->GetNext()) return next;
                          var up = obj;
                          while (up = up->GetUp())
                            if (up == stopAt) return NULL;
                            if (next = up->GetNext()) return next;
                        // Do DoFunction(obj) for all obj that are
                        // children or grand-children of parent.
                        var parent = doc->FindObject(...);
                        var obj = parent->GetDown();
                        while(obj)
                          DoFunction(obj);
                          obj = GetNextHierarchyObject(obj, parent);
                      On 21/12/2002 at 07:28, xxxxxxxx wrote:
                      Thank you for the info, Mikael.
                      I think I will stick with the recursive version (it is working now 🙂 It is more elegant and I believe that for the purpose it serves will do just fine.
                      Now, on to the next chalanges of my next plug-in 😉
                      Rui Batista
                        On 09/03/2005 at 11:13, xxxxxxxx wrote:
                        \> GetActiveTagR(op)
                        \>  while (op)
                        \>  var atag=GetActiveTag(op);
                        \>  if (atag)
                        \>     return (atag);
                        \> atag=GetActiveTagR(op->GetDown());
                        \>  if (atag)
                        \>     return atag;
                        \> op=op->GetNext();
                        \> return NULL;
                        \> GetActiveTagA(doc)
                        \>  return GetActiveTagR(doc->GetFirstObject());
                        \> main(doc,op)
                        \>  var atag=GetActiveTagA(doc);
                        \>  if (atag)
                        \>  var ob=atag->GetObject();
                        \>  println("Active Tag on Object "+ob->GetName());
                        Weird, but where is the GetActiveTag function being called in line 5 from the GetActiveTagR function???
                          On 10/03/2005 at 06:26, xxxxxxxx wrote:
                          In "resource/modules/coffee/convenience.cof":
                              GetActiveTag(op)
                               var tag = op->GetFirstTag(); if (!tag) return NULL;
                               if (tag->GetBit(2)) return tag; // first element is already the active one
                               return tag->SearchNext(2);
