    Preferences - button [SOLVED]
    4 Posts 0 Posters 365 Views
      On 09/01/2015 at 02:21, xxxxxxxx wrote:
      Cinema 4D Version:   16
      Platform:      Mac OSX  ;
      Hey
      I just make my first steps in c++ - usually i use python.
      I try to create a PrefsDialogObject with buttons - where can i get the click and run some code ?
        On 09/01/2015 at 07:31, xxxxxxxx wrote:
        There's an example in the C++ docs under "PrefsDialogObject".
        Have you looked at that one?
        *Edit-
        Hmm. I just took a look at the online R16 docs and it doesn't seem to be there anymore.
        There is a pretty full example in the R14 C++ docs though.
          On 09/01/2015 at 08:25, xxxxxxxx wrote:
          PrefsDialogObject[URL-REMOVED] is based on NodeData[URL-REMOVED]. So to find ouf if a button was pressed you have to implement NodeData::Message[URL-REMOVED] and check for the MSG_DESCRIPTION_COMMAND[URL-REMOVED] message. The data is a DescriptionCommand[URL-REMOVED] object which contains the ID of the pressed button.
          virtual Bool Message(GeListNode* node, Int32 type, void* data)
           if(type == MSG_DESCRIPTION_COMMAND)
               DescriptionCommand* dc = (DescriptionCommand* ) data;
               if(dc)
                   const Int ID = dc->id[0].id;
                   if(ID == MY_BUTTON)
                       GePrint("button pressed");
           return SUPER::Message(node,type,data);
          We are currently working on the R16 documentaiton so missing parts will be added.
            On 09/01/2015 at 14:03, xxxxxxxx wrote:
            Thanks 🙂 work
