    GetPixelInfoPoint trouble [SOLVED]
    3 Posts 0 Posters 262 Views
      On 19/12/2014 at 15:50, xxxxxxxx wrote:
      Cinema 4D Version:   15,16
      Platform:      Mac OSX  ;
      I'm using GetPixelInfoPoint in a tool to get information about vertexes of an object that are inside an area.
      The information is returned inside a ViewportPixel structure and the vertex is returned in variable i.
      But if the x,y coordinates provided in GetPixelInfoPoint don't match with any vertex of the object, the i variable returns 0.
      However, the x,y coordinates could match the vertex number 0 of the object.
      How can I know if a value of zero in the i variable means that there is no vertex in that coordinate or if it is reporting vertex number 0?
        On 20/12/2014 at 06:29, xxxxxxxx wrote:
        _<_t_>_ViewportPixel[URL-REMOVED]* GetPixelInfoPoint ( Int32[URL-REMOVED] x,
        Int32[URL-REMOVED] y
        ) <_<_t_>_
        Retrieves point information at the pixel position ( x , y ).
        Parameters
        | [in]| x| An X coordinate within the viewport. Must be  0  <=  x  <  w , where  w  is the width given to Init()[URL-REMOVED].
        [in] y A Y coordinate within the viewport. Must be  0  <=  y  <  h , where  h  is the height given to Init()[URL-REMOVED]_<_t_>_d>
        Returns
        The retrieved point information, or  nullptr  if no information could be retrieved. The ViewportSelect[URL-REMOVED] instance owns the pointed viewport pixel..
        check against nullptr not 0
          On 20/12/2014 at 12:59, xxxxxxxx wrote:
          Thank you, Mohamed.
          I made it work now 🙂
