    Forward text and case sensitivity routine
    6 Posts 0 Posters 1.2k Views
      On 18/12/2002 at 05:11, xxxxxxxx wrote:
      Cinema 4D Version:   7.303
      Platform:    Mac  ;
      I've created a Find Object command using a COFFEE plugin I've written. Unfortunately it's case sensitive and there doesn't seem to be a case insensitive function in COFFEE, though I think there might be something like that in C++ which I can't use because of the learning curve - COFFEE is distraction enough from the creative work.
      Another thing I'd love to have in my Find dialog box is the same forward lookup that you get in C4D native dialogs, saving you having to type the whole string.
      A search of the old archive revealed there was a Japanese user who claimed to have the latter routine, but his site link returned Not Found and searching Google produced to result.
      Does anyone have either of these two routines written in COFFEE that they could share? Or if you have it as a C++ library of some kind, would there be a way of making use of it in a COFFEE plugin?
      I'm sure I'm not the only one who would hugely appreciate this. Once you start building dialogs to enter names of objects, you realize how much these two routines are needed.
      Thanks in advance!
        On 18/12/2002 at 12:32, xxxxxxxx wrote:
        this is what I have used for my COFFEE plugins all the time:
            CheckHierarchy(obj, stopAt)
              if (!obj) return NULL;
              var next;
              if (next = obj->GetDown()) return next;
              if (next = obj->GetNext()) return next;
              var up = obj;
              while (up = up->GetUp())
                if (up == stopAt) return NULL;
                if (next = up->GetNext()) return next;
            struppercase(str)
             var i;
             for (i = 0; i < sizeof(str); ++i)
              if (str[i] >= 97 && str[i] <= 122)
               str[i] -= 32;
             return str;
            SearchObject(str_name)
             var length,char,can_length,i;
             var input;
             var my_new_group;
            var match;
            var group;
             var candidate;
             var doc = GetActiveDocument();
             if(!doc) return NULL;
             group = doc->GetFirstObject();
             if (sizeof(str_name)==0) return NULL;
             input = struppercase(str_name);
             while ( group )
              length = sizeof(input);
              candidate = struppercase (group->GetName());
              can_length = sizeof(candidate);
              if (can_length < length) length = can_length;
              i = 0;
              do
               if ( !match ) { match = candidate; }
               if  ( strcmp (candidate,input) == 0 )
                match = candidate;
                my_new_group = group;
                break;
               if  ( strcmp (match,input)  == 0 ) break;
               if  ( strcmp (match,candidate)  == 0 ) break;
               if  ( strcmp (match,candidate)  != 0 )
                 if (input[i] == candidate[i])
                  if(sizeof(match)<(i+1))
                    match = candidate;
                  else
                   if ( input[i] != match[i] )
                    match = candidate;
                    break;
                   else
                    i++;
                 } // if (input[i] == candidate[i])
                 else break;
                } // if  ( strcmp (match,candidate)  != 0 )
                 else break;
              } while (i<length);
               group = CheckHierarchy(group, NULL);
               if (!my_new_group) my_new_group = doc->GetFirstObject();
               return my_new_group;
        Feel free to use it for whatever you want.
        Best
        Samir
          On 18/12/2002 at 17:35, xxxxxxxx wrote:
          Wow, thanks, Samir!! Many many thanks! I'm much obliged. Wishing you tons of good karma and very happy holidays and a prosperous New Year! You totally rule, man!!
          Cheers, 🙂
            On 18/12/2002 at 18:55, xxxxxxxx wrote:
            Oups, I've run into a problem - don't know how to update a static text field in the dialog with the output of the SearchObject function as I type my input into an edit field. I can error check the output and get a string out of it, but calling CreateLayout again or setting the static text string variable doesn't update the static field. I'm working around this problem at the moment by sending the output to the status bar instead, which is satisfactory but not elegant. I must be missing something obvious....
            Thanks!
              On 19/12/2002 at 01:07, xxxxxxxx wrote:
              In the Dialog Class or one of its methods just use SetString(ID,string). On the outside you will have to use the dialog constructor like dialog->SetString(ID,string);
                On 19/12/2002 at 03:48, xxxxxxxx wrote:
                Thanks a lot! 🙂
