    my expresso-node example, and questions
    4 Posts 0 Posters 897 Views
      On 16/12/2002 at 03:43, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      Platform:      Mac OSX  ;
      Language(s) :     C++  ;  XPRESSO  ;
      I made an Expresso node based on Mikael Sterner's example in "Topic: Nodes that Iterate",
      and some of his other examples.
      (my node is not suppose to iterate).
      It works, but I have no idea if I did it right...
      Also, it has one problem: When nothing is connected to the inport,
      i want to get the value directly from the inport, but the ...->Calculate(bn,r,c) returns NULL!
      So, how do I get the import values without having to connect them to something?
      BTW: Life would be easier if all of Maxon's own nodes where available in source.
      Thanks!
      kris
      Complete source code follows: (with some more questions).
      #include "c4d.h"
      #include "c4d_operatordata.h"
      #include "Kaaref1.h"
      // forward declarations for functions from Mikael Sterner's post in "Topic: from port->SetData".
      // I use these because port->GetData and ->SetData cause Cinema to crash.
      GeData GvGetPortGeData(GvNode* node, GvPort* port, GvRun* run);
      Bool GvSetPortGeData(const GeData& ge_data, GvNode* node, GvPort* port, GvRun* run);
      const GvOperatorID KAAGETTAG1_ID = 10983430; // just random
      static LONG input_ids[] = { 0 };
      class KaaGvRef1 : public GvOperatorData
      private:
           GvCalcTable* table; // not used... What is it for?
           LONG mode;
           LONG steps;
      KaaGvRef1(void) : table(NULL) {}
           Bool Init(GeListNode *node)
                // Use iCreateOperator instead!
           virtual Bool iCreateOperator(GvNode *bn)
                BaseContainer* data = bn->GetOpContainerInstance();
                if (!data) return FALSE;
                data->SetLong(STEPS, 3);
                //return SUPER::iCreateOperator(bn); // SUPER undefined...
                return GvOperatorData::iCreateOperator(bn);
      Bool InitCalculation(GvNode *bn, GvCalc *c, GvRun *r)
                BaseContainer *data = bn->GetOpContainerInstance();
                steps = data->GetLong(STEPS);
                mode = data->GetLong(MODE_ID);
      void FreeCalculation(GvNode *bn, GvCalc *c)
      Bool Calculate(GvNode *bn, GvPort *port, GvRun *r, GvCalc *c)
                if (!port) return TRUE;
                // Calculate inport
                GvPort* inport = bn->GetInPortFirstMainID(INPORT_LINK);
                if (!inport) return FALSE; // never happens?
                inport = inport->Calculate(bn, r, c); // link
                if (!inport) return FALSE; // hapens when the inport is not connected
                // this is where I want to get data from the node itself!
      // Get the data from the inport
                BaseList2D * mylist2D = NULL; // can't use AutoAlloc
                GeData linkdata = GvGetPortGeData(bn, inport, r);
                BaseLink* test = linkdata.GetBaseLink();
                if (test && test->GetLink(bn->GetNodeMaster()->GetDocument()))
                     mylist2D = test->GetLink(bn->GetNodeMaster()->GetDocument());
                     GePrint(mylist2D->GetName());
                else {
                     GePrint("no link");
      // do I have to get the inport data for each outport i wish to calculate?
                // or is it a bette way?
      switch(port->GetMainID()) // maby not needet for one outport?
                     // is this the right way, when you have many outports? What is most efficient?
                     case OUTPORT_LINK:
                          BaseObject * b = (BaseObject* )mylist2D;
                          for (LONG i = 0; i<steps; i++){
                               switch(mode){
                                    case GETDOWN:
                                         b = b->GetDown(); break;
                                    case GETUP:
                                         b = b->GetUp(); break;
                                    case GETPRED:
                                         b = b->GetPred(); break;
                                    case GETNEXT:
                                         b = b->GetNext(); break;
                               if (!b) break;
                          AutoAlloc<BaseLink> bl;
                          bl->SetLink(b);
                          GvSetPortGeData(GeData(bl), bn, port, r); // returns bool
                          break;
      static NodeData* Alloc(void) { return gNew KaaGvRef1; }
      Bool RegisterKaaref1()
           return GvRegisterOperatorPlugin(
                KAAGETTAG1_ID, "Kaaref1", 0,
                KaaGvRef1::Alloc, "Kaaref1", 0,
                ID_GV_OPCLASS_TYPE_GENERAL, ID_GV_OPGROUP_TYPE_GENERAL, 0, NULL);
      // Kaaref1.res
      CONTAINER Kaaref1
           NAME Kaaref1;
           INCLUDE GVbase;
           GROUP ID_GVPROPERTIES
                LONG MODE_ID
                     CYCLE
                          GETDOWN;
                          GETUP;
                          GETPRED;
                          GETNEXT;
                LONG STEPS { MIN 0; }
           GROUP ID_GVPORTS
                LINK INPORT_LINK {INPORT; STATICPORT; CREATEPORT;}
                LINK OUTPORT_LINK {OUTPORT; STATICPORT; CREATEPORT;}
      // Kaaref1.h
      #ifndef _Kaaref1_H_
      #define _Kaaref1_H_
      enum
           MODE_ID               = 1000,
                GETDOWN          = 0,
                GETUP,
                GETPRED,
                GETNEXT,
      STEPS = 2000,
           INPORT_LINK = 3000,
           OUTPORT_LINK = 4000
      #endif
      // Kaaref1.str
      STRINGTABLE Kaaref1
           Kaaref1 "Kaaref1";
           MODE_ID               "Mode";
                GETDOWN          "GetDown()";
                GETUP          "GetUp()";
                GETPRED          "GetPrev()";
                GETNEXT          "GetNext()";
           STEPS "Steps";
           INPORT_LINK "in";
           OUTPORT_LINK "out";
        On 17/12/2002 at 02:19, xxxxxxxx wrote:
        Well, first of all the Xpresso API isn't officially supported at the moment. But that being said here's a better example using some convenience functions I learned along the way:
            #include "c4d.h"
            // Updated versions:
              if (!node || !port) return GeData();
              GvPortDescription pd;
              if (!node->GetPortDescription(port->GetIO(), port->GetMainID(), &pd)) return GeData();
              GvDataInfo* info = GvGetWorld()->GetDataTypeInfo(pd.data_id);
              if (!info) return GeData();
              GvDynamicData data;
              GvAllocDynamicData(node, data, info);
              if (!port->GetData(data.data, data.info->value_handler->value_id, run)) return GeData();
              CUSTOMDATATYPEPLUGIN* pl =
                FindCustomDataTypePlugin(data.info->data_handler->data_id);
              if (!pl) return GeData();
              GeData ge_data;
              if (!CallCustomDataType(pl, ConvertGvToGeData)(data.data, 0, ge_data)) return GeData();
              return ge_data;
              if (!node || !port || !run) return FALSE;
              if (!node->GetPortDescription(port->GetIO(), port->GetMainID(), &pd)) return FALSE;
              if (!info) return FALSE;
              GvDynamicData data;
              if (!pl) return FALSE;
              if (!CallCustomDataType(pl, ConvertGeDataToGv)(ge_data, data.data, 0)) return FALSE;
              if (!port->SetData(data.data, data.info->value_handler->value_id, run)) return FALSE;
            const GvOperatorID KAAGETTAG1_ID = 1010893; // From PluginCafe!
            static LONG input_ids[] = { INPORT_LINK, 0 }; // Use this for the input ports!
            enum { INPORT_LINK_INDEX };
            // Defines super
            INSTANCEOF(KaaGvRef1, GvOperatorData)
                return GvBuildInValuesTable(bn, ports, c, r, input_ids);
                GvFreeValuesTable(bn, ports);
              Bool Calculate(GvNode *bn, GvPort *port, GvRun *run, GvCalc *calc)
                if (!port) return FALSE;
                LONG steps = data->GetLong(STEPS);
                LONG mode = data->GetLong(MODE_ID);
                GvValue* vinport = ports.in_values[INPORT_LINK_INDEX];
                if (!vinport) return FALSE; // Doesn't matter that it never happens; always check pointers!
                if (!vinport->Calculate(bn, GV_PORT_INPUT, run, calc, 0)) return FALSE;
                GvPort* inport = vinport->GetPort();
                GeData inportdata = GvGetPortGeData(bn, inport, run);
                BaseDocument* doc = bn->GetNodeMaster()->GetDocument();
                if (!doc) return FALSE;
                BaseLink* link = inportdata.GetBaseLink();
                if (!link) return FALSE;
                BaseList2D* list = link->GetLink(doc);
                if (!list) return FALSE;
                case OUTPORT_LINK:
                    BaseObject* obj = static_cast<BaseObject*>(list);
                    for (LONG i = 0; list && i < steps; ++i)
                      switch(mode)
                      case GETDOWN: obj = obj->GetDown(); break;
                      case GETUP: obj = obj->GetUp(); break;
                      case GETPRED: obj = obj->GetPred(); break;
                      case GETNEXT: obj = obj->GetNext(); break;
                    if (!bl) return FALSE;
                    bl->SetLink(obj);
                    return GvSetPortGeData(GeData(bl), bn, port, run);
                return FALSE;
            private:
              GvValuesInfo ports;
            const LONG ID_GV_OPGROUP_MY = 1010850;
            const LONG ID_GV_OPCLASS_MY = 1010851;
            static const String* GetMyGroupName()
              static String mygroup("My Group");
              return &mygroup;
            static BaseBitmap* GetMyGroupIcon()
              // Never used
              static AutoAlloc<BaseBitmap> icon;
              if (!icon) return NULL;
              if (icon->GetBw() == 0)
                icon->Init(24, 24);
                icon->Clear(200, 0, 0);
              return icon;
            static const String* GetMyClassName()
              static String mygroup("My Class");
              return &mygroup;
            static BaseBitmap* GetMyClassIcon()
              // Never used
                icon->Init(24, 24);
                icon->Clear(0, 0, 200);
              return icon;
                icon->Init(24, 24);
                icon->Clear(100,200, 0);
              static GV_OPCLASS_HANDLER myclass;
              myclass.class_id = ID_GV_OPCLASS_MY;
              myclass.GetName = GetMyClassName;
              myclass.GetIcon = GetMyClassIcon;
              if (!GvRegisterOpClassType(&myclass, sizeof(myclass))) return FALSE;
              static GV_OPGROUP_HANDLER mygroup;
              mygroup.group_id = ID_GV_OPGROUP_MY;
              mygroup.GetName = GetMyGroupName;
              mygroup.GetIcon = GetMyGroupIcon;
              if (!GvRegisterOpGroupType(&mygroup, sizeof(mygroup))) return FALSE;;
                ID_GV_OPCLASS_MY, ID_GV_OPGROUP_MY, ID_GV_IGNORE_OWNER, icon);
          On 17/12/2002 at 05:00, xxxxxxxx wrote:
          I compiled it, and it works!
          Had to change "list" in "for (LONG i = 0; list && i < steps; ++i)" to "obj"
          Nice to have a custom class and group (GvRegisterOpClassType, GvRegisterOpGroupType)
          Did you just give them random IDs?
          Thank you.
            No, they must be unique IDs from plugincafe. (Every time you see a seemingly random number it's a good bet that it's a unique ID.)
