    Retrieving Listbox Information [SOLVED]
    3 Posts 0 Posters 347 Views
      On 10/12/2014 at 17:44, xxxxxxxx wrote:
      The documentation for how to .GetLink () is confusing. It says I need an instance of a LinkboxUI.
      I don't know how to retrieve what's contained in the linkbox. Would I need to create the LinkBoxUI instance? If so, how exactly do you do that?
      Simple code setup for the UI. Linkbox and a button. Press the button, print what's in the linkbox (well, that's the goal).
      from c4d import gui
      class guiDialog ( gui.GeDialog ) :
          lb = 1000
          btn = 1001
          def CreateLayout ( self ) :
              self.AddCustomGui ( self.lb, pluginid = c4d.CUSTOMGUI_LINKBOX, name = "Target Object", flags = c4d.BFH_SCALEFIT, minw = 466, minh = 15 )
              self.AddButton ( self.btn, c4d.BFH_SCALEFIT, 120, 15, 'Okay' )
          def Command ( self, id, msg ) :
              if id == self.btn:
                  print 'object name'
          dialog = guiDialog ()
          dialog.Open ( dlgtype = c4d.DLG_TYPE_MODAL )
        On 11/12/2014 at 01:52, xxxxxxxx wrote:
        to get the link of a linkbox simply call the GetLink()[URL-REMOVED] function of your linkbox. AddCustomGui()[URL-REMOVED] will return this linkbox. Either store the returned object or get it using FindCustomGui()[URL-REMOVED].
                 linkbox = self.FindCustomGui(id=4000,pluginid = c4d.CUSTOMGUI_LINKBOX)
                  if linkbox is not None:
                      linkedObject = linkbox.GetLink(documents.GetActiveDocument())
                      if linkedObject is not None:
                          print linkedObject
          On 11/12/2014 at 10:14, xxxxxxxx wrote:
          Ah, FindCustomGui(). That's what I was looking for!
          Thank you!
