    Extracting Metadata [SOLVED]
    3 Posts 0 Posters 400 Views
      On 09/12/2014 at 21:07, xxxxxxxx wrote:
      Are there metadata linked to a cinema4d file?
      How can we extract them in a txt file or in XML or in any other format so that they can be used further?
      Nishant
        On 10/12/2014 at 02:37, xxxxxxxx wrote:
        to get information like the author, copyright or creation date you can access the document's data via GetDocumentData()[URL-REMOVED].
          data =  doc.GetDocumentData(c4d.DOCUMENTSETTINGS_DOCUMENT)
          print data[c4d.DOCUMENT_INFO_AUTHOR]
          print data[c4d.DOCUMENT_INFO_PRGCREATOR_NAME]
        Then you can write this information to a file like you want. If you want to access this data from another application you have to use the C++ Melange library[URL-REMOVED].
          On 10/12/2014 at 03:26, xxxxxxxx wrote:
          Thanks. It was very helpful.
          Nishant
