    Extracting a thumbnail of C4d file. [SOLVED]
    4 Posts 0 Posters 426 Views
      On 27/11/2014 at 03:23, xxxxxxxx wrote:
      Hi all,
      I am trying to extract the thumbnail of a C4d file. I don't want to use rendering as it is time consuming. Do we  have any other option of saving a frame in png, tif or jpeg format. Any other method which can help me here would be fine too.
      Nishant
        On 27/11/2014 at 04:11, xxxxxxxx wrote:
        Hello Nishant,
        you might try this one:
        Just a test doc with a cube...
        As it uses the hardware render, it is not that time consuming:
        import os
        from c4d import bitmaps, documents, storage
        def WriteBitmap(bmp, format=c4d.FILTER_JPG,settings=c4d.BaseContainer()) :
          mfs = storage.MemoryFileStruct()
          mfs.SetMemoryWriteMode()
          hf = storage.HyperFile()
          if hf.Open(0, mfs, c4d.FILEOPEN_WRITE, c4d.FILEDIALOG_NONE) :
              if not hf.WriteImage(bmp,format,settings) :
                  return None
              hf.Close()
          return mfs
          doc.InsertObject(c4d.BaseObject(c4d.Ocube))
          flags = c4d.DRAWFLAGS_FORCEFULLREDRAW
          c4d.DrawViews(flags)
          rd = doc.GetActiveRenderData().GetData()
          xres = int(rd[c4d.RDATA_XRES])
          yres = int(rd[c4d.RDATA_YRES])
          bmp = bitmaps.BaseBitmap()
          bmp.Init(x=xres, y=yres, depth=24)
          rd[c4d.RDATA_RENDERENGINE] = c4d.RDATA_RENDERENGINE_PREVIEWHARDWARE
          res = documents.RenderDocument(doc, rd, bmp, c4d.RENDERFLAGS_EXTERNAL)
          mfs = WriteBitmap(bmp)
          if res==c4d.RENDERRESULT_OK:
              previewBmp = doc.GetDocPreviewBitmap()
              if not previewBmp.InitWith(mfs) :
                  raise StandardError, "Not working"
          path = "/Users/monkeytack/Desktop/projekt_x/2014-11-05_projekt_x.c4d"
          c4d.documents.SaveDocument(doc, path , c4d.SAVEDOCUMENTFLAGS_0, c4d.FORMAT_C4DEXPORT)
          c4d.documents.KillDocument(doc)
          c4d.documents.LoadFile(path)
        Best wishes
        Martin
          On 27/11/2014 at 04:41, xxxxxxxx wrote:
          to get the preview image of a (saved) scene simply use GetDocPreviewBitmap()[URL-REMOVED].
            On 01/12/2014 at 21:25, xxxxxxxx wrote:
            Thanks for the help guys.
            Nishant
