    moving the axes and let the polygon stay [SOLVED]
    3 Posts 0 Posters 367 Views
      On 19/11/2014 at 13:59, xxxxxxxx wrote:
      Hi all,
      I want to move a polygon with his axis to Y=0 and let the polygon
      stay above it?
      To move the axis to 0 is no Problem.
      But what do I have to do that the polygon will stay above?
      Any ideas.
      Thanks a lot
        On 20/11/2014 at 08:39, xxxxxxxx wrote:
        it seems there is no dedicated function to do this. You can edit the axis of an point object by moving the object and then transform the points of the object:
          if op == None:
          if op.IsInstanceOf(c4d.Opoint) == False:
          # the offset of the axis
          offset = c4d.Vector(100,0,0)
          # move object
          m = op.GetMg()
          m.off = m.off + offset
          op.SetMg(m)
          # transform points
          padr = op.GetAllPoints()
          pcnt = op.GetPointCount()
          for i, point in enumerate(padr) :
              point = point - offset
              op.SetPoint(i,point)
          op.Message(c4d.MSG_UPDATE)
        In a more complex situation you may have to work with a offset matrix[URL-REMOVED].
          On 21/11/2014 at 00:56, xxxxxxxx wrote:
          Hey you arre my hero 🙂
          Thanks for your code.
          Ronald
