    User button test on Python Generator [SOLVED]
    5 Posts 0 Posters 555 Views
      On 19/11/2014 at 03:35, xxxxxxxx wrote:
      I can't quite get this to work.  I've figured out how to do button press testing using Tags with code I've seen around the forums - but when I create a button directly on my Python Generator, what goes on inside message() seems different and the usual code doesn't work..
        On 20/11/2014 at 11:03, xxxxxxxx wrote:
        can you tell us what code you are using with the Tags? And what kind of "usual code" you are using?
          On 20/11/2014 at 11:49, xxxxxxxx wrote:
          Hi
          This is the code I used for tags with a user data button on it..
          > def message(id, data) :
          >     if id == 17:
          >         print "UserData-ID: ", data["descid"][1].id
          > # test for button ID and execute code
          ...but with the same code on a Python Generator the IDs are large numbers, which don't seem anything to do with the button ID.
            On 21/11/2014 at 02:40, xxxxxxxx wrote:
            when I use your code I have no problem getting the correct user data button ID as defined in the User Data manager. As always I suggest to use the correct identifiers and no magic numbers. The code can look like this:
            def message(id,data) :
              if id == c4d.MSG_DESCRIPTION_CHECKUPDATE:
                  # check if button
                  if data["descid"][1].dtype == c4d.DTYPE_BUTTON:
                      # get id
                      buttonID =  data["descid"][1].id
            If the problem persists you could give us some more information about your code and your system.
              On 21/11/2014 at 03:38, xxxxxxxx wrote:
              Yeah that worked fine for me Sebastian, thank you..
