    OBJECT_OPERATOR_OBJECT_OUT
    7 Posts 0 Posters 853 Views
      On 18/11/2014 at 06:52, xxxxxxxx wrote:
      I'm working on a python script.
      I want to make some expresso nodes with it.
      Adding the node and a position-output port works fine, but when I try to add an object-output port it does nothing.
      No errors, but no port as well.
      Here is the code I use:
      from c4d import gui
      pointobject = doc.GetActiveObject()
      xpressotag = c4d.BaseTag(c4d.Texpresso)
      xpressotag.SetName("PointLock XPresso")
      op.InsertTag(xpressotag)
      nodemaster = xpressotag.GetNodeMaster()
      basenode = nodemaster.CreateNode(nodemaster.GetRoot(), c4d.ID_OPERATOR_OBJECT, None, 100, 100)
      basenodeobjectoutput = basenode.AddPort(c4d.GV_PORT_OUTPUT, c4d.GV_OBJECT_OPERATOR_OBJECT_OUT)
      basenodepositionoutput = basenode.AddPort(c4d.GV_PORT_OUTPUT, c4d.ID_BASEOBJECT_REL_POSITION)
      c4d.modules.graphview.RedrawMaster(nodemaster)
      I think there isn't anything wrong with my code, and I found "GV_OBJECT_OPERATOR_OBJECT_OUT inside Applications -> CINEMA 4D R16 -> resource -> modules -> expression tag -> description -> gvobject.res
      What I want is the port to be added.
      Greetings,
      Casimir
        On 18/11/2014 at 07:26, xxxxxxxx wrote:
        Correct me if I'm wrong but I am pretty sure this Port is broken in python. I haven't used that bit of code in R16 yet but from the sound of it, it's still broken? What I have done to bypass this is to add a link userdata to the object and add the object to the link and then make an output port for the link. (A lot of unnecessary code)
          On 19/11/2014 at 03:55, xxxxxxxx wrote:
          thanks for reporting this. A bug report was filed.
            On 20/11/2014 at 03:05, xxxxxxxx wrote:
            Hi Sebastian,
            Do you know when (approximately) the bug will be fixed?
            @ShawnFrueh, thanks, I'll look into it!
              On 20/11/2014 at 08:15, xxxxxxxx wrote:
              I don't know when this bug will be fixed. Also I can't make any statements about future Cinema 4D releases.
                On 21/11/2014 at 06:58, xxxxxxxx wrote:
                @ShawnFrueh,
                Thanks again for your answer!
                After a bit of digging how to make user data I came up with a perfectly working script to create an object port, like you did it!
                Here is my code, for the people not yet understanding it:
                from c4d import gui
                  userdata = c4d.GetCustomDatatypeDefault(c4d.DTYPE_BASELISTLINK)
                  userdata[c4d.DESC_NAME] = "Object Data"
                  linkobject = op.AddUserData(userdata)
                  op[linkobject] = op
                  basenodeobjectoutput = basenode.AddPort(c4d.GV_PORT_OUTPUT, c4d.DescID(c4d.DescLevel(c4d.ID_USERDATA, c4d.DTYPE_SUBCONTAINER, 0), c4d.DescLevel(1)), message = True)
                Greetings,
                Casimir
                  On 21/11/2014 at 09:15, xxxxxxxx wrote:
                  Glad I could help 🙂
