    Render to Picture Viewer and RenderDocument woes
    16 Posts 0 Posters 2.4k Views
      On 04/11/2014 at 14:22, xxxxxxxx wrote:
      Alrighty!
      Thank you guys for your help. I was able to get it working with the CallCommand() and running the rest of the script in a separate thread.
      I'll post a truncated version of the working code, just in case someone else runs into this issue.
      import c4d, thread, time
      def someFunction ( renderCheck, time ) :
          while renderCheck == True:
              time.sleep( 5 ) # waits 5 seconds before running rest of loop
              renderCheck = c4d.CheckIsRunning ( c4d.CHECKISRUNNING_EXTERNALRENDERING )
              print 'Checking if render is still rendering'    # still part of the while loop
          print 'Render is done'    # outside of the while loop
      def main () :
          c4d.CallCommand (12099) # calls the renderer
              if renderCheck == True:
                  thread.start_new ( someFunction, ( renderCheck, time ) )
        On 04/11/2014 at 14:49, xxxxxxxx wrote:
        Hi Herbie,
        great, that it is working for you!
        Your code look like the suggestion, but there is no need to pass the rendercheck to your User Thread function.
        A simpler version:
        import os,time, thread
        def isRendering(time,os) :
          print(time.ctime())
          while c4d.CheckIsRunning ( c4d.CHECKISRUNNING_EXTERNALRENDERING ) :
              print("render in progress...")
              time.sleep(4)
          print(time.ctime())
          print("render complete.")
          c4d.CallCommand(12099)
          if c4d.CheckIsRunning ( c4d.CHECKISRUNNING_EXTERNALRENDERING ) :
              thread.start_new(isRendering,(time,os))
        @scott
        I´m also really interested in your suggestion!
        I thought that the c4d.documents.RenderDocument command will render from a temp doc anyway?
        Except you set RENDERFLAG_NODOCUMENTCLONE.
        The problem is, that if you start the rendering from the main thread with c4d.documents.RenderDocument
        the main thread is blocked and busy, too.
        If you start it from a userthread, it´ll render in the background and you can edit your scene.
        But if it comes to the bitmaps.ShowBitmap(bitmap) part, you´ll get this Error message.
        RuntimeError: illegal operation, invalid cross-thread call.
        It seems to me, that ShowBitmap must be called from the main thread?
        If you or anybody else has an explanation or a working example to share, I´ll be very glad!
        Best wishes
        Martin
          On 04/11/2014 at 16:16, xxxxxxxx wrote:
          I'm not having any trouble running code in the script manager. Or editing the scene while the renderer is running without using a custom thread.
          The only thing that happens is that the timeline scrubber and the ShowBitmap() output freezes in the PV window. But the renderer is still rendering the scene.
          Is that what you're talking about?
          Can you post an example of starting the render from a thread?
            On 04/11/2014 at 16:34, xxxxxxxx wrote:
            That sounds promissing ! Could you please show a working example?
            This is what I´m trying with a userthread:
            from c4d import gui,bitmaps
            from c4d.threading import C4DThread
            class UserThread(C4DThread) :
              def Main(self) :
                  doc = c4d.documents.GetActiveDocument ()
                  doc2 = doc.GetClone()
                  rd = doc2.GetActiveRenderData ()
                  rdata = rd.GetData ()
                  xres = int ( rdata[ c4d.RDATA_XRES ] )
                  yres = int ( rdata[ c4d.RDATA_YRES ] )
                  bmp = bitmaps.BaseBitmap ()
                  bmp.Init ( x = xres, y = yres )
                  print c4d.threading.GeGetCurrentThreadCount()
                  print c4d.threading.GeGetCurrentThread()
                  thr = c4d.threading.GeGetCurrentThread()
                  res = c4d.documents.RenderDocument( doc2, rdata, bmp, renderflags = c4d.RENDERFLAGS_EXTERNAL, th = thr )
                  print res
                  if res == c4d.RENDERRESULT_OK:
                      print res
                      bitmaps.ShowBitmap ( bmp )
                  pass
            thread = UserThread()
            thread.Start()
              print "the main"
            Thanks in advance
            Martin
              On 04/11/2014 at 18:08, xxxxxxxx wrote:
              What I'm saying is that I don't use custom threads when rendering and working at the same time.
              They don't seem to be necessary.
              When c4d.CallCommand (12099) is executed. I can still run scripts and work in the scene while it's rendering. There should be no problem doing both at the same time.
              The only down side is that the scrubber and the image preview are frozen when doing that.
              Rendering seems to be fully threaded and automatically handled by C4D.
              However, things like the scrubber and the preview image don't.
              The only code example I have is for C++. But it doesn't use threads or the RenderDocument() function.
              Both of those things seem to be problematic when trying to render while working on the scene at the same time. Which is why I asked to see your code.
              I haven't had much luck with using custom threads while rendering.
                On 05/11/2014 at 03:09, xxxxxxxx wrote:
                Thanks Scott, if you like, you can send me a pm with the c++ code?
                The call command handles all the threading operations and nothing is blocked and you can run your script, for sure. (not even the scrubber)
                Herbie was asking for running his code after the rendering, I guess.
                So I've decided to just use the CallCommand in the beginning of the script, then have the rest of the code run after that.
                And I was asking for manage it without using a call command with the RenderDocument() function.
                But yea, you can get grafic driver errors and other fancy stuff, with trying that one in a Userthread.
                On the other hand, if you try it in the main function of your script everything is blocked.
                Could anyone please confirm that it is not possible in python to re-create the c4d.CallCommand (12099)?
                Thanks in advance
                Martin
                  On 05/11/2014 at 07:59, xxxxxxxx wrote:
                  Sure. I can post it here.
                  It's very small.
                  //This is how to render the scene to a temporary document while working on the scene
                  //Instead of loading a new document. You create a clone of it
                    Filename name = doc->GetDocumentName();    //Gets the name & extension  of the document without the path
                    Filename path = doc->GetDocumentPath();    //Gets the file's path, minus the file's name and extension
                    String fullPath = path.GetString() + "\\" + name.GetString();   //Combine them to get the full file path
                    //Save the scene before we open it back up and render it
                    //This lets us change the scene and get accurate rendering results
                    SaveDocument(doc, fullPath, SAVEDOCUMENTFLAGS_0, FORMAT_C4DEXPORT);
                    //Open the scene
                    BaseDocument *docCopy = LoadDocument(fullPath, SCENEFILTER_OBJECTS | SCENEFILTER_MATERIALS, NULL);
                    //Insert the scene into the CINEMA editor list of documents
                    InsertBaseDocument(docCopy);
                    SetActiveDocument(docCopy);
                    CallCommand(12099);        //Render to picture viewer
                    KillDocument(docCopy);
                    On 06/11/2014 at 05:25, xxxxxxxx wrote:
                    Thanks Scott!
                    I thought you might have a c++ kernel level threading example, which shows what´s behind the callcommand 😄,
                    Anyway, in this case and in python I´m fine with the callcommand.
                    Best wishes
                    Martin
                      On 07/11/2014 at 04:35, xxxxxxxx wrote:
                      Hi
                      _<_t_>_
                      English »
                      < id="SL_lng_to">< value="af">Afrikaans< value="sq">Albanian< value="ar">Arabic< value="hy">Armenian< value="az">Azerbaijani< value="eu">Basque< value="bn">Bengali< value="be">Belarusian< value="bg">Bulgarian< value="ca">Catalan< value="zh-CN">Chinese (Simp)< value="zh-TW">Chinese (Trad)< value="hr">Croatian< value="cs">Czech< value="da">Danish< value="nl">Dutch< value="en">English< value="eo">Esperanto< value="et">Estonian< value="tl">Filipino< value="fi">Finnish< value="fr">French< value="gl">Galician< value="ka">Georgian< value="de">German< value="el">Greek< value="gu">Gujarati< value="ht">Haitian Creole< value="iw">Hebrew< value="hi">Hindi< value="hu">Hungarian< value="is">Icelandic< value="id">Indonesian< value="ga">Irish< value="it">Italian< value="ja">Japanese< value="kn">Kannada< value="ko">Korean< value="lo">Lao< value="la">Latin< value="lv">Latvian< value="lt">Lithuanian< value="mk">Macedonian< value="ms">Malay< value="mt">Maltese< value="no">Norwegian< value="fa">Persian< value="pl">Polish< value="pt">Portuguese< value="ro">Romanian< value="ru">Russian< value="sr">Serbian< value="sk">Slovak< value="sl">Slovenian< ed="" value="es">Spanish< value="sw">Swahili< value="sv">Swedish< value="ta">Tamil< value="te">Telugu< value="th">Thai< value="tr">Turkish< value="uk">Ukrainian< value="ur">Urdu< value="vi">Vietnamese< value="cy">Welsh< value="yi">Yiddish
                      <_<_t_>_
                      Options : History : Help : Feedback
                      Text-to-speech function is limited to 100 characters
                      I ask the question here not to start a new topic.
                      I need begin rendering immediately after the start of C4D project.
                      I can't use c4d.CallCommand (12099) or bitmaps commands because in this case need to move the slider on the timeline. How to run a render immediately after opening the file?
                        On 07/11/2014 at 05:41, xxxxxxxx wrote:
                        I actually can´t see a reason, why this code should not run properly and why the callcommand should freeze your timeline.
                        Could you please give it a try and report if something goes wrong?
                        EDIT
                        sorry forgot the scenefilters, fixed.
                        import c4d,os
                          filename = c4d.storage.LoadDialog(c4d.FILESELECTTYPE_SCENES)
                          if not filename or not os.path.isfile(filename) :
                          doc = c4d.documents.LoadDocument(filename, c4d.SCENEFILTER_OBJECTS | c4d.SCENEFILTER_MATERIALS | c4d.SCENEFILTER_DIALOGSALLOWED | c4d.SCENEFILTER_PROGRESSALLOWED | c4d.SCENEFILTER_NONEWMARKERS | c4d.SCENEFILTER_SAVECACHES)
                          c4d.documents.InsertBaseDocument(doc)
                          c4d.documents.SetActiveDocument(doc)
                        Best wishes
                        Martin
                          On 07/11/2014 at 07:28, xxxxxxxx wrote:
                          The Picture Viewer window has it's own timeline.
                          And if you are changing your scene while rendering. The timeline in that PV window does indeed freeze. And so does the image history images. And so does the preview window image.
                          Basically. Everything in the PV freezes.
                          However. The rendering is still running in the background. And as soon as you stop changing the scene. All of the rendered images will be dumped from memory into the PV. And the PV timeline will unfreeze and jump to the same frame as the frame being rendered.
                          This is what I meant when I said that the rendering sems to be threaded, and handled automatically by C4D. But things like ShowBitmap() are not.
                          It might be possible to get each bitmap that is rendered by using a GeDialog plugin and a custom thread. Combined with SpecialEventAdd() to send out a signal to it's CoreMessage() method. Then ask for the bitmap in the CoreMessage() method.
                          This is the workaround mentioned in the C++ docs under: Important Threading Information
                            On 07/11/2014 at 12:35, xxxxxxxx wrote:
                            Thanks again Scott!
                            for clarification this time
                            and the hint with the c++ docs, interesting.
                            Best wishes
                            Martin
                              On 12/11/2014 at 00:27, xxxxxxxx wrote:
                              Thanks for answers!
                              _<_t_>_
                              English »
                              <_<_t_>_
