    Initializing GvNode Parameters
    4 Posts 0 Posters 985 Views
      On 10/12/2002 at 14:50, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      When I retrieve the node's data container and set values they do not seem to stick once the node is created. Any ideas?
      darf
        On 11/12/2002 at 00:21, xxxxxxxx wrote:
        Could you describe what you do more precisely? Do you allocate a node, insert something into its container and then insert it into an Xpresso tag?
          On 11/12/2002 at 08:40, xxxxxxxx wrote:
          Te question sould be:
          How do I initialize the GvNode parameters ( originally created by the fact they are defined in the .res ) to a value in the Init function and ave it actually work so that when the port is created for that value it will already by defaulting to the value set in the Init function?
          darf
            On 12/12/2002 at 01:12, xxxxxxxx wrote:
            The Init() function canot be used for GV nodes. Use iCreateOperator() instead:
                  virtual Bool iCreateOperator(GvNode *bn)
                    BaseContainer* data = bn->GetOpContainerInstance();
                    if (!data) return FALSE;
                    data->SetVector(GVTEST_OFFSET, Vector(1,2,3));
                    return SUPER::iCreateOperator(bn);
