    Python primitives [SOLVED]
    3 Posts 0 Posters 273 Views
      On 31/10/2014 at 06:00, xxxxxxxx wrote:
      Hello everyone.
      I have been thinking about this one for a little while. I entered this topic into the python section as I'm hopeful that I won't have to leave the python environment. - That said I'm happy to (try to) delve into c++ if necessary.
      I was wondering if it is possible to make new object primitives?. There are two arms to this:
      Scenario A: I'd like to make mograph effectors which don't have the python effector interface. Is it possible to make an effector using the baseEffector class?
      Scenario B: I'd like to make some new object primitives such as a few versions of platonic like things which aren't in the regular toolset. - Do  I have to make a plugin for each object or is there a better way to do this?
      Any info, even to help me understand why this may not be feasible is appreciated.
      Adam
        On 31/10/2014 at 06:25, xxxxxxxx wrote:
        you can only create plugins based on the basic plugin classes[URL-REMOVED]. The EffectorData[URL-REMOVED] class is currently only available in the C++ SDK[URL-REMOVED].
        You can create new primitives using ObjectData[URL-REMOVED] plugins. To simplify your workflow you could create just one plugin object that can create all the different primitives you want. Then the user could use a dropdown parameter to select what object should be created.
          On 31/10/2014 at 10:49, xxxxxxxx wrote:
          Thanks for your response, that's really useful.
          Time to go to c++ school...
