    Accessing Menu Items Dialogs [SOLVED]
    4 Posts 0 Posters 328 Views
      On 28/10/2014 at 14:47, xxxxxxxx wrote:
      I've been messing with scripts, but not so much plugins.. so this is where I am a tad confused.
      How would I access a menu item's dialog?
      Example.
      I would like to access Mesh->Commands->Reset Scale options dialog.
      Now I would not necessarily need to open said dialog, just make sure certain things are checked.
      A macro, if you will.
      I've located the properties of the dialog in   resource\res\dialogs\r_resetaxis.res
      However, I have no idea how to use that to execute it those commands.
      Any ideas?
        On 29/10/2014 at 02:37, xxxxxxxx wrote:
        you cannot edit this dialog or set it's values. But you can execute a special modeling command using SendModelingCommand()[URL-REMOVED]:
          settings = c4d.BaseContainer()
          settings[c4d.MDATA_RESETSYSTEM_COMPENSATE] = True
          settings[c4d.MDATA_RESETSYSTEM_RECURSIVE] = True
          utils.SendModelingCommand(command = c4d.MCOMMAND_RESETSYSTEM,
                                      list = [op],
                                      bc = settings,
                                      doc = doc)
          On 29/10/2014 at 11:22, xxxxxxxx wrote:
          Thank you so much for your quick response!
          So that format can be applied to any dialog box, correct? ( Well, any command listed in the SDK )
          If this is the case, you have just opened up a world of options for me!
          This is going to be fantastic!
            On 30/10/2014 at 02:32, xxxxxxxx wrote:
            SendModellingCommand has nothing to do with dialogs. It simply calls a command with the given settings (these settings are typically presented in a dialog but this function may not necessarily interfere with that).
            You can use CallCommand[URL-REMOVED] to execute every command that is registered in Cinema (also plugin commands).
