    NameError: global name is not defined [SOLVED]
    4 Posts 0 Posters 661 Views
      On 23/10/2014 at 13:02, xxxxxxxx wrote:
      I have a problem when calling my function IterateHierarchy.
      It raises the NameError: global name 'IterateHierarchy' is not defined
      I've looked at many topics to fix this problem;
      I came upon this: Your function should be defined before you call it.
      But the weird thing for me is, that it is defined before I call it. This makes me kinda confused.
      Here is my code:
      import os
      import sys
      from c4d import gui, plugins, bitmaps
      PLUGIN_ID = 1000002
      BPBUTTON = 1002
      CROBUTTON = 1011
      askedforbase = False
      control = False
      class ControlPoseHandler(plugins.TagData) :
        pass
      def GetNextObject(op) :
            if op == None:
                return None
      if op.GetDown() :
                return op.GetDown()
      while not op.GetNext() and op.GetUp() :
                op = op.GetUp()
      return op.GetNext()
      def IterateHierarchy(op) :
            if op is None:
      count = 0
      while op:
                count += 1
                print op.GetName()
                op = GetNextObject(op)
      return count
      def Init(self, node) :
            tag = node
            data = tag.GetDataInstance()
      global askedforbase
      if askedforbase == False:
                global askbase
                askbase = gui.QuestionDialog("Are you sure this is the base pose?")
                askedforbase = True
      global doc
                tagobject = tag.GetObject()
                global controlobject
                controlobject = doc.SearchObject("Control_Goal")
      global baseposition
                baseposition = controlobject.GetAbsPos()
            count = IterateHierarchy(tagobject)
      def Execute(self, tag, doc, op, bt, priority, flags) :
      if askbase == False:
                tag.Remove()
      print "The askedforbase is: ", askedforbase
      def Message(self, node, type, data) :
            if type == c4d.MSG_DESCRIPTION_COMMAND:
                if data['id'][0].id == BPBUTTON:
                    doc.StartUndo()
                    doc.AddUndo(c4d.UNDOTYPE_CHANGE, controlobject)
                    controlobject.SetAbsPos(baseposition)
                    doc.EndUndo()
        bmp = bitmaps.BaseBitmap()
        bitmapfile = os.path.join(dir, "res", "ControlPoseHandler.tif")
        result = bmp.InitWith(bitmapfile)
        if not result:
            print "Error loading bitmap!"
      okyn = plugins.RegisterTagPlugin(id = PLUGIN_ID, str = "ControlPoseHandler", info = c4d.TAG_VISIBLE | c4d.TAG_EXPRESSION, g = ControlPoseHandler, description = "ControlPoseHandler", icon = bmp)
        print "ControlPoseHandler initialized", okyn
      Thanks for your help!!
        On 23/10/2014 at 14:50, xxxxxxxx wrote:
        self.IterateHierarchy(tagobject)
        will do it.
        it´s a function which is defined inside your class.
        Best wishes
        Martin
          On 23/10/2014 at 15:11, xxxxxxxx wrote:
          Thanks!! that does it.
          I also had to change my functions to:
          def GetNextObject(self, op) :
                if op == None:
                    return None
          if op.GetDown() :
                    return op.GetDown()
                    op = op.GetUp()
          return op.GetNext()
          def IterateHierarchy(self, op) :
                if op is None:
          count = 0
          while op:
                    count += 1
                    print op.GetName()
                    op = self.GetNextObject(op)
          return count
            On 23/10/2014 at 15:20, xxxxxxxx wrote:
            you´re welcome !
