    need help: cloth tag
    7 Posts 0 Posters 557 Views
      On 19/10/2014 at 02:18, xxxxxxxx wrote:
      Cinema 4D Version:   16
      Language(s) :   C.O.F.F.E.E  ;   XPRESSO  ;  PYTHON  ;
      hi everyone..
      i need help
      i want to do calculate cache in my multiple cloth tags in one user data button...
      please anyone can help...
      thanks
      (sorry for the my poor english)_<_mytubeelement_>_<mytubeelement =""loadBundle":true" ="relayPrefs" id="myTubeRelayElementToTa_<_mytubeelement_>_nt>
        On 19/10/2014 at 09:43, xxxxxxxx wrote:
        Hi Suda,
        thanks for stopping by and don't worry, nobody will be blamed for his English. I'm no native speaker myself.
        If I understand correctly, you want to automate the job of caching cloth tags. By intuition I'd try that with a Python script.
        Unfortunately the SDK Support Team can't help with developing such scripts from scratch. But I'm quite sure, there's somebody in the community, who may want to try himself on this. Anybody?
          On 19/10/2014 at 11:42, xxxxxxxx wrote:
          Hi Suda,
          with Python you can do something like this:
          def GetNextObject(op) :
            if op==None:
                return None
            if op.GetDown() :
                return op.GetDown()
            while not op.GetNext() and op.GetUp() :
                op = op.GetUp()
            return op.GetNext()
          def IterateHierarchy(op) :
            ClothTagList=[]
            if op is None:
            count = 0
            while op:
                count += 1
                if op.GetTag(100004020)!= None: #id for the cloth tag
                    ClothTagList.append(op.GetTag(100004020))
                op = GetNextObject(op)
            return ClothTagList
            first = doc.GetFirstObject()
            ClothTagList=IterateHierarchy(first)
            for i in ClothTagList:
                c4d.CallButton(i, c4d.CLOTH_DO_CALCULATE )
            On 20/10/2014 at 00:00, xxxxxxxx wrote:
            Another idea would be to directly simulate the Cache button.
            You can use  c4d.CallButton(...) to do this. As parameters you'll need to pass the object and the button ID.
            Be aware: This call needs to be done from the main thread. For a normal Python script this is no problem, in a Python Plugin you might need to care.
              On 20/10/2014 at 00:25, xxxxxxxx wrote:
              Hi Andreas,
              I´ve already used the call button in the script.
              But thank you for the good hint to check the main thread inside a plugin.
              As I´m scripting the snippet yesterday between changing diapers and singing a lullaby.
              Here a more efficient script without a list and more error checking.
              @ Suda
              Hope this helps.
              from c4d import gui
                if op==None:
                    return None
                if op.GetDown() :
                    return op.GetDown()
                    op = op.GetUp()
                return op.GetNext()
                if op is None:
                count = 0
                while op:
                    count += 1
                    if op.GetType!=c4d.Opolygon:
                        dialog=gui.MessageDialog("A Polygon object for caching is needed",c4d.GEMB_OK)
                        if dialog== 1:
                        ClothTag = op.GetTag(100004020)
                        c4d.CallButton(ClothTag, c4d.CLOTH_DO_CALCULATE )
                if first == None:return
              Best wishes
              Martin
                On 20/10/2014 at 00:31, xxxxxxxx wrote:
                Sorry, monkeytack, I didn't look closely enough. I didn't want to derogate your effort or idea.
                Thanks for helping Suda out.
                Would you allow us to integrate your code into our Python SDK docs?
                  On 20/10/2014 at 02:36, xxxxxxxx wrote:
                  Hi Andreas,
                  no need to apologise, every thing is alright.
                  And Yes, feel free to integrate everything I´ve posted, if it fits and someone can take advantage of it.
                  It´s a pleasure.
                  Best wishes
                  Martin
