    Create Xref with python
    4 Posts 0 Posters 990 Views
      On 18/10/2014 at 11:53, xxxxxxxx wrote:
      I've found a couple posts about this but no clear answers.
      https://developers.maxon.net/forum/topic/8036/10449_xref-python-command
      Is it possible to create an Xref object and pass in a file path using python rather than just opening the dialog to search for it? If so, does someone have a code snippet they can share?
      EDITED:
      I've got this going so far, but the filepath isn't updating. I guess maybe I need to load a file into the Xref object?
          op = c4d.BaseObject(c4d.Oxref)
          rocket = "/component1.c4d"
          op.GetObjectLink(rocket)
          op[c4d.ID_CA_XREF_FILE_SELECT] = "component1.c4d"
          op[c4d.ID_CA_XREF_NAMESPACE] = "rocket"
          op[c4d.ID_CA_XREF_GENERATOR] = 1
          box = c4d.BaseObject(c4d.Ocube)
          box.SetName("new")
          doc.InsertObject(box)
          doc.InsertObject(op)
        On 20/10/2014 at 00:59, xxxxxxxx wrote:
        Due to some limitations it is currently not possible to set the filename parameter of a Xref object in Python.
          On 21/10/2014 at 08:43, xxxxxxxx wrote:
          Any idea of when this will be fixed?
            On 21/10/2014 at 09:59, xxxxxxxx wrote:
            Sorry, I don't know when this will be fixed.
