    Turning Reflectance Layers On / Off
    6 Posts 0 Posters 615 Views
      On 15/10/2014 at 17:34, xxxxxxxx wrote:
      Hey there!
      Is there a way to turn on / off different layers in the Reflectance channel using the Python API?  I want to be able to toggle the eyeball switch on my Specular layer based on some User Data.  Any help would be greatly appreciated.
      Thanks!
      joey
        On 16/10/2014 at 07:15, xxxxxxxx wrote:
        Reflectance is currently not supported by the Python API. You can only access it with the C++ Material class[URL-REMOVED].
          On 10/10/2017 at 18:05, xxxxxxxx wrote:
          This is now possible.
          """Name-US: Toggle Reflectance
          Description-US: Toggle the first reflectance layer on/off.
          from c4d import gui
              mat = doc.GetActiveMaterial()
              if not mat:
              doc.StartUndo()
              doc.AddUndo(c4d.UNDOTYPE_CHANGE, mat)
              layer = mat.GetReflectionLayerIndex(0) # Get the top-most layer
              if not layer:
              flags = layer.GetFlags()
              if flags is None:
              active_toggled_flags = flags ^ c4d.REFLECTION_FLAG_ACTIVE
              layer.SetFlags(active_toggled_flags)
              doc.EndUndo()
            On 05/11/2017 at 05:59, xxxxxxxx wrote:
            thanks for the update, is it now possible to enable/disable individual Reflectance Layers in Xpressso?
            My hack is going to be just to turn the Brightness to 0% otherwise lol
              On 06/11/2017 at 02:41, xxxxxxxx wrote:
              the activity state of a reflectance layer is stored in a flag, not a parameter. So I'm afraid it is not possible to edit this value using XPresso.
                On 07/11/2017 at 05:44, xxxxxxxx wrote:
                Hey,
                Thanks for the answer.  I did test using Xpresso to turn the Brightness of the Color channel to 0% and it works the same as turning the flag to 0.  Or at least it Renders the same, not sure on the back end.
                I need to get back into Python and C++ again.  Xpresso can do so much though.
                Matt
