    Update Bitmaps in the AM
    7 Posts 0 Posters 1.3k Views
      On 06/12/2002 at 05:21, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      Hello
      I 've got a nice preview bitmap in my object now.
      It is implemented as shown in the "Bitmap for PuginObjects" Thread
      But i don't know how to update it 😞
      Michael
        On 09/12/2002 at 09:41, xxxxxxxx wrote:
        In GetDParameter() you should increment the 'dirty' variable of the BitmapButtonStruct everytime the bitmap needs to be updated.
          On 17/02/2003 at 10:51, xxxxxxxx wrote:
          Is it that simple? It doesn´t work for me. I am incrementing it all the time (dirty++) so it should update all the time shouldn´t it?
          Samir
            On 17/02/2003 at 14:26, xxxxxxxx wrote:
            already got it.
              On 25/02/2005 at 20:04, xxxxxxxx wrote:
              Samir, I seem to be having a problem incrementing 'dirty'.
              Can you possibly shed some light on how you got it working?
              Chris
                On 26/02/2005 at 07:28, xxxxxxxx wrote:
                Here is a codesnippet:
                Bool TreeGenData::GetDParameter(GeListNode* node, const DescID& id, GeData& t_data, LONG& flags)
                     switch(id[0].id)
                          case TREEGEN_BEND_NOISE:
                                    BitmapButtonStruct bbs(static_cast<PluginObject*>(node), id, bn_dirty);
                                    t_data = GeData(CUSTOMDATATYPE_BITMAPBUTTON,bbs);
                                    flags |= DESCFLAGS_PARAM_GET;
                                    bn_dirty=0;
                                    break;
                                    case TREEGEN_BENDNOISETYPE:
                                    case TREEGEN_BENDNOISESPEED:
                                    case TREEGEN_BENDNOISEANIM:
                                    case TREEGEN_BENDNOISE_SCALE:
                                    case TREEGEN_BENDNOISE_WIND:
                                         bn_dirty++;
                                    break;
                     return ObjectData::GetDParameter(node, id, t_data, flags);
                Hope that helps
                Katachi
                  On 26/02/2005 at 08:18, xxxxxxxx wrote:
                  Thanks Samir, that is pretty much identical to what I've been trying, except I have only been incrementing it in response to a combobox ID.
                  I tried with other control IDs, and everything seems to work except the combobox.
                  I even tried incrementing 'dirty' in 'default:' and it just wont respond to the combobox.
                  Any ideas?
                  -Chris
