    Testing the handling of multiple CPU's?
    3 Posts 0 Posters 823 Views
      On 03/12/2002 at 17:49, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      Is there a setting in C4D or the SDK to set the number of CPUs? I would like to do multi-processor testing of my shader plugin on a single-CPU system. I know some other packages let you set the number of CPUs manually, but I didn't see anything like that in C4D.
      Has anything changed from R7 to R8 for developers with respect to handling multithreading? I read in the R8 press release about it taking advantage of "several innovations in CPU technology (such as Hyperthreading)." I have someone using an R7 plugin with R8 on a dual and getting crashes.
      Jane
        On 04/12/2002 at 02:41, xxxxxxxx wrote:
        Yes, go to Preferences->Common and set Render Threads to something else than Optimal. Now when you render C4D will used the specified number of threads (splitting the image in horizontal segments).
          On 04/12/2002 at 02:42, xxxxxxxx wrote:
          Also, notice that the other threads may take a while to start, so the effect is only visible on scenes that take more than a couple of seconds to render.
