    IN_EXCLUDE in Python
    4 Posts 0 Posters 920 Views
      On 10/10/2014 at 20:38, xxxxxxxx wrote:
      Cinema 4D Version:   R16
      Platform:      Mac OSX  ;
      Language(s) :
      Inserting or deleting objects from an Include/Exclude is not working.
      Tried making a new InExcludeData() and replacing my light data with it. Still doesn't work.
      testInEx = c4d.InExcludeData()
      testInEx.InsertObject(op, 1)
      op[c4d.LIGHT_EXCLUSION_LIST] = testInEx
        On 11/10/2014 at 08:31, xxxxxxxx wrote:
        It should work. But you didn't really post much code.
        I'm guessing this is what you're trying to do?:
        #This script gets all of the selected objects
        #Then creates an area light and inserts the objects into the light's InExclude attribute
          objs = doc.GetActiveObjects(True)    #Get all active objects and their children
          light = c4d.BaseObject(c4d.Olight)   #Create a new light object
          light[c4d.LIGHT_TYPE] = 8            #Set it's  type to area
          doc.InsertObject(light)              #Insert the light into the scene
          inexclude = c4d.InExcludeData()      #Create an InExcludeData class instance
          for obj in objs:
              inexclude.InsertObject(obj,15)   #Insert all active objects into the InExclude data list
                                               #15 is a flag used to make all items selected in the InExclude data attribute
              obj.InsertUnder(light)           #Move the objects under the newly created light
          light[c4d.LIGHT_EXCLUSION_LIST] = inexclude #Update the changes made to the InExclude data list
          On 11/10/2014 at 09:52, xxxxxxxx wrote:
          It works with that code.
          However, I shouldn't have to make a InExcludeData class. I should be able to modify objects in the current one. Heres an example of my situation.
              obj = op    #Get current object
              tag = obj.GetTag(1033673) #get tag that contains the Incude/Exclude
              nextObj = obj.GetNext() #get the object below the current object
              inc = tag[c4d.INCLUDEEXCLUDE] #get the include/exclude from the tag
              inc.InsertObject(nextObj,15) #insert object on tags include/exclude
            On 03/11/2014 at 15:59, xxxxxxxx wrote:
            I guess you just need to write it back to your inexcludelist like:
              #here you update your inexclude list
              tag[c4d.INCLUDEEXCLUDE]= inc
            Best wishes
            Martin
            • M m_adam referenced this topic on
