    Button is pressed on startup of tag plugin[SOLVED]
    5 Posts 0 Posters 441 Views
      On 08/10/2014 at 09:21, xxxxxxxx wrote:
      Hi, I created a little plugin with a few parameters and a button.
      I want to do stuff as a reaction on button clicks, but when I start the plugin, the button gets executed allready once. How can I avoid this?
      This is my code for the button:
      def Execute(self, tag, doc, op, bt, priority, flags) :
      data = tag.GetDataInstance()
      if MYBUTTON:
                print "The button is pressed"
        On 08/10/2014 at 10:57, xxxxxxxx wrote:
        add this function:
        def GetMessageID(data) : #This custom method is used to get the id of your gizmos
            if data is None:
            try:
                return data["id"][0].id
            except:
        and add this to the Message:
        def Message(self, op, type, data) :
            id = GetMessageID(data) # calls to the custom GetMessage() method
        if id == MYBUTTON:
        Thanks to Scott on this forum for teaching me it.
          On 09/10/2014 at 02:39, xxxxxxxx wrote:
          Thanks for the answer!!
          I didn't need to add the GetMessageID though. Fixed it with:
          def Message(self, node, type, data) :
                if type == c4d.MSG_DESCRIPTION_COMMAND:
                    if data['id'][0].id == MOMBUTTON:
            On 09/10/2014 at 02:47, xxxxxxxx wrote:
            casimir your solution is much cleaner. That's exactly how you should do it
              On 09/10/2014 at 13:08, xxxxxxxx wrote:
              Thanks NiklasR!! Your words give me a boost to continue delving into it, harder than ever 😄
